battery tender question
Old Dec 6, 2006 | 12:45 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default battery tender question
I just bought a battery tender and I was wondering do I have to pull the battery out of the car to use it? or can I leave it in and hooked up to the battery cables and just connect the tender to the top posts? ( i have an optima)
Old Dec 6, 2006 | 12:49 PM
vettenuts's Avatar
vettenuts
You can do it either way, although I did have my last Tender short out. I didn't have any problems as a result, but not sure if that would always be the case either.
Old Dec 6, 2006 | 03:17 PM
87bob's Avatar
87bob
Veteran: Coast Guard
I have a Optima Red Top and I bought the Battery Buttler from Lectric Limited it works great. I hooked it to the side posts and that is it. The red power light is always on while the unit is plugged in and the green charge light cycles on/off at the unit does. At a kwick glance I tell that the unit is working.
Old Dec 6, 2006 | 04:26 PM
FKING1's Avatar
FKING1
Leave the bat in. I have done this for years with no problems.
Fred
Old Dec 6, 2006 | 05:47 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Fred
That's what I have been doing.
Old Dec 6, 2006 | 05:57 PM
Vetteoholic's Avatar
Vetteoholic
You can leave the battery alone and just hook It up, just lay a thin towel or cloth on the fender so the cord Isn't touching your paint. Also don't click the hood shut when It's hooked up. Shut the hood so the light goes off, just don't push down on the sides to make It click.
Old Dec 6, 2006 | 05:59 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
yeap, should have included this in my previous post, I do this also....
Old Dec 6, 2006 | 06:07 PM
Gohard777's Avatar
Gohard777
Default battery tenders
good answers, but don't forget to add that battery tenders come with the automatic shutoff or just act like a trickle charger. don't get confused, the auto shut-off's are the only way to go. i have them on my son's 35th anniversary camaro, my 2003 h-d ultra centennial, and my 2004 corvette convertible. they are all in the garage, hooked up. my only problem, i need a multi-charging battery tender, so i can hook them all up to one charger, does anyone know if they make one? ....bob.
Old Dec 6, 2006 | 06:42 PM
devo's Avatar
devo
COOOL!
thanx everyone
Old Dec 6, 2006 | 06:50 PM
bob guzzy's Avatar
bob guzzy
Default battery charger
Go to harbor freight, get there small red charger maintainer, 20 bucks, made by chicago electric, I have three of them, there not sealed units but they do the job at half the price...
Old Dec 6, 2006 | 07:19 PM
devo's Avatar
devo
I bought the float charger made by chicago electric from harbor freight for $9.00!
Old Dec 7, 2006 | 02:19 PM
Humy's Avatar
Humy
I have a red top also, so i hook it up to the side posts without doing anything else - no pulling of fuses, just take the key out, open the door and put them on? I am scared I am going to get zapped
and if I want to take her for a cruise, just unhook, start, and go?
Old Dec 7, 2006 | 05:42 PM
2002 MATRIX SC's Avatar
2002 MATRIX SC
they do make 1 for 4 cars ecklers has it in there catalog for $259
Old Dec 8, 2006 | 12:15 PM
JC in XTC5's Avatar
JC in XTC5
Clip it to the battery where it sits. No problems.
Old Dec 8, 2006 | 12:40 PM
ytwokc5's Avatar
ytwokc5
I bought a couple of them also... one to keep the charge on my lawn tractor battery.
Old Dec 8, 2006 | 07:45 PM
lomoman's Avatar
lomoman
The latest and most technologically advanced is the one from CTEK. Go to ctek.com and check the available videos. Quite impressive. If you can't find them in your area let me know and I will hook you up. Merry Christmas to all.
Old Dec 8, 2006 | 08:37 PM
Gohard777's Avatar
Gohard777
Thank you very much.....bob.
To battery tender question
Old Dec 8, 2006 | 10:09 PM
az57chevy's Avatar
az57chevy
worked for me too
Old Dec 8, 2006 | 10:15 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Fred
Me too. Mine is double faced taped to the side of the battery and stays in the car. whenever the car is in the garage (Summer or Winter) it's plugged in.
Old Dec 9, 2006 | 03:00 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I got one from Advance Auto, it doesn’t say “Battery Tender” though, just make sure what you get has a float feature. I left the battery installed and routed the charger cables up from underneath the car and routed the cables between the firewall and Battery area weatherstripping. Nice and neat!
