Pilot Bearing Q
The input shaft rides on the inside of the pilot bearing, which means the TQ tube needs to come out.
Umm, yeah. Here i was thinking it was beside the dipstick. (kidding)
I need to be more specific. I have to remove my pilot bearing. My plan of attack is to lower rear crossmember, lower rear end/tranny/torque tube. So that leaves me a bellhousing mounted to the back of the motor with the clutch/flywheel/pp in place. What I would then like to do is get the pilot bearing out of the without dropping that assembly. I have the LS7 clutch too, so clearance isn't my friend. When the clutch install was taking place the top bellhousing bolts were more trouble than anything, and getting everything lined up on the reinstall wasn't all that smooth either. I was hoping to avoid all of this.
I discovered when I got home (after clutch install) the new pilot bearing I bought was still in the box-o-parts i supplied, unopened. Now I am having issues.
I was going to get my tranny massaged a little while I was at it, but the guy I want to use doesn't have the means to drop a tranny, he just works on them via benchtop.
My guess is no one has tried this at this point.
My second guess is it's unlikely the O.D. of the pilot bearing is smaller than the I.D. of the clutch center, but it should be a simple manner for someone to measure both components to provide a definitive answer. In addtion you've got to have room for the tool to pull the original.
I guess my only fear is I will invest all of the time in disassembly just to find that I can't my bellhousing off in my garage with jackstands. And then if I do, I can't mange to get everything back in there. Isn't the LS7 clutch thicker than the stock clutch. I thought I read smewhere it wasn't easy to get in.
Also, be very careful when removign your pilot bearing. Their is a freeze out plug in the crank behind the bearing. If you knock it out of place it may start leaking oil and that will drip straight on your clutch.
