lowering C5 question
Dec 7, 2006 | 08:06 AM
I am beibg told that in order to lower my C5 on the stock bolts that their is circlip on top of the bolts that must be removed.
I need to know this before I start this project today so that I may purchase the circlip pliers if I need them.
Thanks in advance.
Dec 7, 2006 | 08:15 AM
Cruise-In VII Veteran
the rear bolts has the clip, leave it there
Dec 7, 2006 | 08:23 AM
Cruise-In V Veteran
St. Jude Donor '04
Quote:
And if you absolutely have to remove it, it's just a snap ring.
Dec 7, 2006 | 08:47 AM
I assume you mean no need to to even mess with the clips. So I can just turn the bolts with no other issues as far as the bolts are concerned correct?
Thanks in advance
Dec 7, 2006 | 10:16 AM
St. Jude Donor '15, '17
Quote:
Thanks in advance
Yes you are correct. I did not have to remove them. About 6 turns is all you want to go. The sweet spot is 20mm down according to GM.
