Intermittent c1267
Old Dec 9, 2006 | 02:59 PM
tatersalad72's Avatar
tatersalad72
8th Gear
Default Intermittent c1267
I've got a 2002 z06. The car has an intermittent problem. When the car is started it may have the c1267 code or it may not. Any ideas where to begin looking?
Thanks,
David
Old Dec 10, 2006 | 05:39 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
My maintenance DVD says;
"Make sure the integrity of the connection between the EBTCM and the BPMV is secure, tight, and free from corrosion. "
If you can't find a connection problem, it's probably the BPMV BUT I'd take it into a trusted dealer to them do a diagnostic on.
Old Dec 10, 2006 | 04:39 PM
tatersalad72
8th Gear
Thanks, I'll check that out this week.
David
Old Dec 10, 2006 | 04:43 PM
GRAY BEARD's Avatar
GRAY BEARD
Thanks,
David
My code list say this is a traction control code for rigth rear inlet valve solenoid---malfunction? So thats where I'd start. Also check connections as tstar says.
Old Dec 13, 2006 | 06:19 PM
tatersalad72
8th Gear
Do you guys think a broken wire to the right rear speed sensor could cause this code?
Thanks,
David
Old Dec 13, 2006 | 06:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO! You most likely have a EBTCM issue. Iys the electrical portion of the module and it is not user serviceable. You can however disconnect the main EBTCM connection, examine it, make sure it is clean and corrosion free and reconnect it. If you have a bad EBTCM, it is an easy self repair. You will save your self about$400 to $1000. dollars depending on where you get your module. Here is a pic of the module EBTCM/BPMV:
Here is a pic of the module removed from the EBTCM/BPMV:
Inside the electrical connector on the module:
New modules are about $700. Remanufactured modules are $350
BC
Old Dec 13, 2006 | 09:37 PM
GRAY BEARD's Avatar
GRAY BEARD
I would go with what Bill said he has helped many people including me. He really knows these cars.
Old Dec 14, 2006 | 03:59 AM
tstar's Avatar
tstar
BC Great pics! As always you come through. Just to make sure I wasn't off base we're basically saying the same thing right?
Old Dec 14, 2006 | 05:09 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Tim
Pull the electrical connectors, examine then, clean them reinstall and see if things change. If they don't, its time for a new EBTCM. In the Navy,,, if things don't work correctly, mechanical agitation (smack the damn thing with a rubber mallet) is sometimes necessary! Ya never know, it might change the symptoms or even fix it.
BC
To Intermittent c1267
