Labor $ for basic cam install?
Old Dec 10, 2006 | 06:06 PM
BarneyZ's Avatar
BarneyZ
Default Labor $ for basic cam install?
I'm considering a mild street cam with LS6 or similar springs and have a couple of questions:
1. If I only change out the valve springs, can the install be done properly (and more easily) without removing the heads?
2. What is a reasonable labor cost for such a job?
Thanks for you input!
Barney
Old Dec 10, 2006 | 06:42 PM
mdhmi's Avatar
mdhmi
Usually $750 - $1,000 for a cam install depending what all else is upgraded at the same time and whether you have long tube headers or not.
Old Dec 10, 2006 | 07:18 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
1: Yes.
2: $750, not including the dyno tune, which is usually needed unless you install a very small cam. Another $500 for that.
Old Dec 10, 2006 | 07:31 PM
InSaNeKaMeL's Avatar
InSaNeKaMeL
what mark said
Old Dec 10, 2006 | 08:26 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Barney
budget 800-1000 bucks...500 for tuning
Old Dec 11, 2006 | 01:29 PM
BMF42's Avatar
BMF42
From: Grand Rapids holy mother its cold here MI used to live in Cali what was I thinking
Don't mean to sound stupid here, but is this mod worth the money (HP wise)
Old Dec 11, 2006 | 01:34 PM
Architect's Avatar
Architect
In an LS6, you won't see more than 2-3 tenths with an aftermarket cam. Not worth $1800 IMO. You'll need heads and headers to see a noticeable gain. Then you're talking $3500-4000. That's supercharger territory with half the gain.
Old Dec 11, 2006 | 04:12 PM
yankeevetteconvert's Avatar
yankeevetteconvert
Why would headers change the price of a cam install?
Old Dec 12, 2006 | 11:24 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Default any DIY way to do it.
does anybody have the procedure to do this without removing heads. Is there a special tool to keep the lifters up in their bores. All the info that I have states to remove the heads as well.
Old Dec 12, 2006 | 12:02 PM
jfrc's Avatar
jfrc
just one more thing to remove and install, that's all
Old Dec 12, 2006 | 01:04 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
They have a special tool to hold the lifters up, but you can make one with some small dowls. You do not need to pull the heads off to change the cam unless you are changing lifters.
Old Dec 12, 2006 | 03:12 PM
RichieRichZ06
St. Jude Donor '08
Thank you for the info. one more question though: Do you know where to purchase such a tool? TIA
RICH
Old Dec 12, 2006 | 03:40 PM
fovsky's Avatar
fovsky
RICH
here is a good start for the special tools you'll need
http://www.thunderracing.com/catalog...&vid=7&pcid=17
trust me...don't skimp on the tools unless you like spending 3x as much time doing this then you anticipated
Old Dec 12, 2006 | 04:31 PM
RichieRichZ06
St. Jude Donor '08
Thank You very much. I just ordered one today.
Old Dec 12, 2006 | 04:45 PM
yankeevetteconvert
Most people/shops don't remove the heads. No need to remove them.
To Labor $ for basic cam install?
