Car not locking
Old Dec 10, 2006 | 10:44 PM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Default Car not locking
The driver side door will not lock sometimes when I push the lock button on my fob. You can here the doors locking but if you watch it, the lock button will try to move to the lock position, but it barely will move. It will not fully engage to the lock position. Other times when you lock the car it will lock. Although, the alarm is always set when I lock the car. Is this a problem with the door control module or what??
Old Dec 10, 2006 | 11:31 PM
4BTINGU's Avatar
4BTINGU
I have the same problem. Read IMPORTANT ELECTRICAL INFORMATION posted at the top. Seems to be what we both need to do!
Old Dec 11, 2006 | 12:02 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
In your case you most likely have a bad door control module. Specificaly, the lock relay. There are two lock control relays in each door module. Lock and un lock. The contacts that pass the voltage to the lock solinoid burn up. There have been people who have replaced the relays with success. There are a couple of post on relar replacement.
Here is a pic of the module:
INSIDE THE MODULE
Hope this helps
BC
Old Dec 11, 2006 | 12:37 AM
white90conv's Avatar
white90conv
I cut open the relay and cleaned the points and it seemed to work ok. But a few months later, the problem came back. I next replaced the relay and that seems to have solved the problem. I had trouble removing the old relay. Get a friend with circuit board experience if you can to do the repair.
There is a post somewhere that lists the relay you need. I got it from Digi-Key and the part number is 255-1239-ND.
Old Dec 11, 2006 | 10:35 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Been there............my replacement info thread:
http://forums.corvetteforum.com/show...highlight=door
Old Dec 11, 2006 | 06:06 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Steve
The pictures in your post didnt work.
Bill C
Old Dec 11, 2006 | 11:18 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Been there/done that. Drivers side door module.
To Car not locking
