Tunnel Plate with higher HP?
Old Dec 11, 2006 | 06:57 PM
kenh's Avatar
kenh
Cruising
Default Tunnel Plate with higher HP?
I recently had a supercharger, headers and exhaust installed on my c5 coupe. It has been recommended to me that I should install a tunnel (stiffening) plate or I could be in danger of twisting the body with 500hp. Any comments?
Old Dec 11, 2006 | 07:39 PM
Just Enough's Avatar
Just Enough
You won't twist the body permanently. You are more likely to churn your tires or explode your diff output shafts. Everything deflects under load so with a stiffer tunnel plate you will deflect less. It reduces squeeks and a stiffer chassis typically handles better.
Old Dec 11, 2006 | 07:55 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
You don't need the plate.People install them to help keep the heat from going into the cabin. We have plenty of 700+rwhp Vette's running around without them
Old Dec 11, 2006 | 08:06 PM
monstermouse's Avatar
monstermouse
My 3/8 plate made a big difference on my set-up. Less twist, shake and heat, especially under hard accleration.
Old Dec 12, 2006 | 12:02 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I noticed my car was a little stiffer, but the big thing was the reduced heat in the cabin and in Texas were it gets hot this is a big help
Old Dec 13, 2006 | 01:41 AM
vmaquera's Avatar
vmaquera
Where do you get the plate? I am modding the drivetrain. Now would be a good time to install said plate.
Old Dec 13, 2006 | 02:52 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
http://www.eliteengineeringusa.com/T...late_Link.html
To Tunnel Plate with higher HP?
