running lean
Old Dec 12, 2006 | 02:49 PM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Default running lean
Kept getting check engine light so took my '04 A4 to the dealer. They found a vacuum leak in the manifold but also found whenever the hood was closed, the engine ran lean. They feel it is the Halltech stinger filter. Even with new manifold gaskets, it still gave them the same problem. Hood open, no problem, hood closed, runs lean.
Anyone have a similar experience or solution?
Old Dec 12, 2006 | 03:55 PM
chaase's Avatar
chaase
St. Jude Donor '12
I would get lean codes when running the Halltech Stinger at the track only , never under normal circumstances. I would check all of the connections and make sure the stinger is sitting as low as possible. It may be the hood pressing down on the airbridge and causing unintended air leakge.
otherwise, take it in for a dyno tune and they can adjust the fuel as necessary.
Chris
Old Dec 12, 2006 | 05:25 PM
rws.1's Avatar
rws.1
The PCM should be able to handle the increased air flow from the stinger. It is supposed to be able to adjust (re-learn) for up to a 25% increase in airflow...
But if you used it in combination with a high flow air bridge a descreened (or after market high flow) MAF and a ported polished throttle body, you would like be outside the tolerances...
Any other goodies that increase the airflow?
Old Dec 12, 2006 | 05:31 PM
vettenuts's Avatar
vettenuts
I thought the 04's were a little sensitive when intake modifications were made, seems a lot of guys were having issues.
Old Dec 12, 2006 | 07:34 PM
worldtraveler
Nope only got the Halltech and cat backs. Will check to make sure the airbridge is sealing well.
thanks.
Old Dec 12, 2006 | 08:00 PM
dpd's Avatar
dpd
is the air bridge loose and sitting too high or the boot going to the throttle housing have a crack? almost sounds like when the hood is closing it is pushing on the air bridge and creating a air leak after the maf.just a thought.
Old Dec 12, 2006 | 08:27 PM
DJMRTS's Avatar
DJMRTS
would a new ported throttle body with a Halltech airbridge throw codes: P 0108 & P 1514?
To running lean
