sleeper cam
Dec 12, 2006 | 06:32 PM
sleeper cam
im just curious if theres a fairly queit idle cam that could put me around 380 rwhp through stock manifolds, just asking
Dec 12, 2006 | 06:43 PM
Quote:
Originally Posted by
glennxx1
228R with the all the other bolt on's could get you really close.
Dec 12, 2006 | 06:49 PM
Dec 12, 2006 | 06:55 PM
CheaTR cam was designed to use stock exhaust, would get you close if not there. Very aggressive ramps and lift though.
Dec 12, 2006 | 11:20 PM
lingenfelter gt2-3 i put down 362 rwhp with ls6 intake and exhaust manifolds . good luck with your choice
john
Dec 13, 2006 | 04:28 AM
FurtralMotorsports F-13 cam puts down some real nice numbers and is pretty quiet.
Dec 13, 2006 | 06:54 AM
thanks for all the input guys im going to look into these and see what my options are
Dec 13, 2006 | 08:52 AM
I would also check out MTI's Stealth II Cam, designed for that very purpose.
Brent
Dec 13, 2006 | 09:04 AM
also, how many RPMs can a stock LS1 turn safely? im sure that will be a factor in my cam selection as well, or will the new valve springs etc move that number up?(the RPM safe range)
Dec 13, 2006 | 09:21 AM
i have the 224, very smooth
the key is to have a 114 or higher LSA
i think the Z06 cams had 117
Dec 13, 2006 | 09:38 AM
brentg454
Brent
Dec 13, 2006 | 10:22 AM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
brentg454
Brent
Stealth I is perfect
Dec 13, 2006 | 01:16 PM
glennxx1
Depends on the year, earlier years I believe have more concerns with regard to rod bolts than later years since the bottom end is the same as the LS6.
Dec 13, 2006 | 02:28 PM
A TR224 puts down nice numbers and can be tuned to idle close to stock. I would do the 112 LSA to get maximum results though.
