Header Install...Time Required????
Old Dec 14, 2006 | 01:01 PM
00'Vette's Avatar
00'Vette
Originally Posted by C5_Baker
I called a local speed shop here in Phoeinx the other day and they said that they would bill 7 hours, at $95 per, for the header install.
I have looked at the how to's on this subject and I would think that I could do it myself, if I had what I needed here, in that amount of time.
Does this seem excessive or about average?
I did my own header install with a buddy and we took our sweet *** time............going very slowly and it took us about 5 1/2 hours. If you are prepped and ready it shouldn't take much longer than that
Old Dec 14, 2006 | 01:07 PM
C5_Baker's Avatar
C5_Baker
I agree GPRacer. That's why I posted my question, something didn't seem right about it.
What do you think about TorchRed's offer GP? Do you have a garage and a set of jack stands that could be used for the installs? If not, I would be happy to split the cost of a new set of jack stands and you can keep them. Unfortunately the same cannot be said for a new garage.
Old Dec 14, 2006 | 01:15 PM
gpracer1's Avatar
gpracer1
Yeah, I live alone in a house with 2 car garage, vaulted ceiling. I have 2 jacks and stands and ramps. I will probably go out and buy the tallest stands I can find, they are cheap. I think they said you need at least 24 to 30 inches to get the headers in from the bottom on one side. It will be a good excuse for me to clean out the garage anyhow
Old Dec 14, 2006 | 01:17 PM
torchredfrc's Avatar
torchredfrc
The drivers side goes in from the bottom and needs the car pretty high off the ground to get it in.
I have a set of Craftsman high lift (yellow/black in color) stands. They work ok for the rear of the car but it would be good to have stands with a wider base to hold the front end. When I did mine, I borrowed a old heavy duty red set of stands from a friend.
Old Dec 14, 2006 | 01:54 PM
C5_Baker's Avatar
C5_Baker
COOL!!! We need to set this up then! GP I can go in halves for the new jack stands. Sounds like all Torch would need to bring is the experience.
Old Dec 14, 2006 | 02:01 PM
gpracer1's Avatar
gpracer1
I just called Jet Hot. They are here in Tempe (Phoenix)
$329 for the extreme sterling jet hot, good for nitrous and superchargers and lasts longer than the standard $279 job. I am gonna order my headers tomorrow and then have them coated. Should be ready by Jan.
Ill just charge myself $329 for the header install and give the money to Jet Hot. And still save $270 for other gofaster stuff.
Old Dec 14, 2006 | 02:49 PM
C5_Baker's Avatar
C5_Baker
Who are you ordering your headers from?
Old Dec 14, 2006 | 02:53 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by torchredfrc
The 1st time I did it - 5 hours.
The 2nd time I did it - 3 hours.
The 3rd time I did it - 2.5 hours.
The 4th time I did it - 2 hours.
Hardest part is the drivers side. The new (made by Borla) LG Headers are much easier to install than their 1st generation headers.
I typically just loosen the engine mount on the driver side, pry the motor up a bit and drop 'em in, did my DYNATECH LTs in about 2.5 hours, however, that was my third setup in the header department.
Micah
Old Dec 14, 2006 | 03:19 PM
blackc598's Avatar
blackc598
it took me 9 1/2 hours to install GHL's by myself on my back and doing the air tube swap. in all great learning experience...would i do it again Fu*k No!!
Old Dec 14, 2006 | 03:23 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Come on man, it wasn't that bad was it?
Old Dec 14, 2006 | 03:37 PM
torchredfrc
The AIR tube swap does suck. I'm glad to see these 2 are 01's & thus no swap required!
Old Dec 14, 2006 | 03:43 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I just blocked it all off and got rid of my air system altogether.
Old Dec 14, 2006 | 03:46 PM
  #33
gpracer1's Avatar
gpracer1
LG street with cats $1095 shipped. Order before Xmas. I just called them too, to confirm price and shipping.
  #34
I was quoted from two different shops prices of $425 and $400 to install a set of LT headers, high flow cats, and x-pipe. $700 seems very high.
Old Dec 14, 2006 | 04:11 PM
  #35
C5_Baker's Avatar
C5_Baker
What if any additional mod's are required with the LG Street series? I am still considering which way to go.
Did you go with the 1 3/4? Are there any additional changes that will be required with these? I want to make sure that I have all my ducks in a row.....know wut i mean....
Old Dec 14, 2006 | 04:23 PM
  #36
gpracer1's Avatar
gpracer1
What kind of headers are you looking at?
LG streets are supposed to be bolt on with no problems/cutting/welding.
And they are on sale
Old Dec 14, 2006 | 04:35 PM
  #37
torchredfrc
Basically you just need the adapter plug from LG to fit your rear sensors to the forward plug (electrical). You can also get extensions to use the rear sensors but I just put plugs in the rear bungs and disabled the rear sensor DTC's in the PCM.
The PM I sent you & gpracer... verify with LG but I know for sure with the pro series they recommend the F-Body gasket rather than reusing your gasket. I've not done a street series installation but they look very similar to the pro series.
To Header Install...Time Required????
Old Dec 14, 2006 | 04:47 PM
  #38
C5_Baker's Avatar
C5_Baker
I am thinking of going with the LG Streets as well. I got your PM TorchRed...Thanks for the info!
Old Dec 14, 2006 | 05:18 PM
  #39
blackc598's Avatar
blackc598
IT WASNT THAT BAD... BUT NOW THAT I HAVE A BETTER PAYING JOB I WOULDNT GO THROUGH THE HASSLE OF IT AGAIN. BUT I DO LOVE GETTING MY HANDS DIRTY!!
Old Dec 14, 2006 | 05:20 PM
  #40
EHS's Avatar
EHS
Fair price.
You can also do it yourself, and see what it is worth afterwards.
