Alignment problem?
Old Dec 16, 2006 | 02:42 PM
Sparky22's Avatar
Sparky22
Default Alignment problem?
The driver side front tire on my 02 Z has worn down to almost to the threads on the OUTSIDE of the tire. This is the only tire on the car with a problem. My question is, is it possible that just is an allignment problem or will it be something more serious?
Most of the posts I've read have wear issues with the inside of the tire but mine is the outside.
I do not track the car so If I need an alignment what do I want them to do to get even wear on all the tires? + or - camber or something like that? I'm a little out of my league here when it comes to the setup I need/want.
Any suggestions on where to have the car serviced? Dealer, corvette shop? I live in Milwaukee WI.
Old Dec 16, 2006 | 03:25 PM
AU N EGL's Avatar
AU N EGL
too much POSITIVE camber will cause this. time for an alignment
-1.0* camber up front
See other thread for alignment specs
Good Luck
Old Dec 17, 2006 | 11:23 AM
Sparky22's Avatar
Sparky22
ttt
To Alignment problem?
