OK here's how I screwed up. I tried to use grease to hydraulicly push out the pilot shaft roller bearing, like I've done many times on lots of small blocks and big blocks, back in the day. Doesn't work on LS model engines. Hollow crank! So, I packed in about two handfuls of grease, before I realized it wasn't going to work. Next day borrowed a slide hammer, put a 3/8" bolt in it, heated up the bolt to give me the correct angle and got the bearing out. Cleaned out the grease. Now I can see the freeze plug, inside the crank, cocked over at an angle.
To get it out, I'll drill a 1/8" pilot hole and put a self tapping long screw into it and pull it out with the slide hammer.
Is this a special part or can I get any old freeze plug that matches up in size?
Is there a specific depth that it has to be installed?
I've got friends in a machine shop so I can make an installer tool if you can give me specifications for it.
I don't think gettin' it out will be the problem. The problem will be getting the new freeze plug and getting it installed to the correct depth. Is it covered in the factory service manual? Should I get one at the dealership?
When I get the new one, should I put shalack on it or thread locker so it won't come loose? I'd hate to have it come loose and then lose oil pressure and ruin the clutch and the motor similtaniously.
This guy at work was telling me that drilling might be a problem. Says I might not get all the shaving out and then have them end up stuck in a passage some where starving a bearing.
I've got a 4" long 3/8-24 bolt and will grind it down and put a curve in it to hopefully get that sucker out.
Hopefully I can get it out with out deforming it, so I can match it up for a new one.
Wow, I feel for ya. I hate when that kinda crap happens.
A little birdie told me that the plug may be as shown below....the same birdie mentioned a number similar to Vettenuts above but it didn't seem to be valid either. Hope this helps.
GM PART # 10044811
GM LIST: $6.63
Description: Plug
Not that it helps you now but here is the puller that I used a while back that worked great. Borrowed it from AutoZone. I hope this helps someone in the future.
Plug, Expansion Plug Cup Shape 1" Steel (CR/SFT HOLE) 97-01 Part # 9427698 (doesn't appear to be correct, but the number is hard to read)
Note that I looked on Fred Beans and GMPartDirect and couldn't find this part number, so it may be incorrect.
Thanks, man. I got one from some one at work today. 1" diameter, not steel. Also gave me a brass one, said it was better since it won't rust. Didn't tell him what it was going on. Think I'll stick with the the other as it's lighter. The original wasn't steel though. I tried to stick a magnet to it, and it wouldn't. Oh well.
Also, thanks for the illistration. Wasn't sure about the depth. A mechanic at the dealership said there'd be a shoulder that would stop it from going to far. Now, I can measuer with the tail end of my sliding calipers.
This is a great website.
