When a 427 is NOT ENOUGH??
Old Dec 18, 2006 | 01:34 PM
AU N EGL's Avatar
AU N EGL
Default When a 427 is NOT ENOUGH??
Originally Posted by MerlinPro@LSiTech
FIRST WARHAWK BLOCK BUILT and RUN.
Well it sure took awhile (our fault) but the first Development Warhawk was built and tested by the crew at E/T Performance in Walled Lake, Mi.
As reported by Eric at E/T, all went well in this preliminary stage of testing.
The numbers; 440 cubic inches-4.185 x 4.000. 16.0-1 compression. A cam over .900 lift. Of course a great pair of E/T heads flowing 430 near max lift. Normally aspirated. Seven pulls, 860 HP @ 7500 RPM.
Eric reports that at 4.185 there is .065-.070 sleeve left which is what C5R comes with at 4.125. Engine had nominal temps and pressures at this power level. E/T intends to test to at least the 1200 HP level after PRI.
You can see this engine at E/T's display at PRI or contact E/T for more data. A big THANK YOU to the E/T gang.
http://www.ls1tech.com/forums/showthread.php?t=620614
Note: Oh EG. Your New WARHAWK BLOCK IS WAITING.
Old Dec 18, 2006 | 01:37 PM
supercoupe01's Avatar
supercoupe01
Old Dec 18, 2006 | 02:05 PM
cyclerage23's Avatar
cyclerage23
That is ridiculous.
Old Dec 18, 2006 | 02:50 PM
Justin-Sane's Avatar
Justin-Sane
or you can buy the new LSX engine block....511ci.
Old Dec 18, 2006 | 03:45 PM
02gt350's Avatar
02gt350
860 hp NA? jesus i would kill myself
Old Dec 18, 2006 | 04:41 PM
bernrex's Avatar
bernrex
Initally promoted as 1250 HP I thought. Or was that a different version of the Warhawk?
Will the GM motor be a superior product ?
Old Dec 18, 2006 | 10:55 PM
ScreaminDemon's Avatar
ScreaminDemon
Now that's a lot of power!
Old Dec 18, 2006 | 11:22 PM
NSTG8R's Avatar
NSTG8R
mmm ..
Old Dec 19, 2006 | 12:16 AM
CleteZ16's Avatar
CleteZ16
St. Jude Donor '09
On 93 octane?? No way.
Old Dec 19, 2006 | 12:47 AM
mdhmi's Avatar
mdhmi
And I'm sure there are folks here who think that's streetable.
Old Dec 19, 2006 | 12:51 AM
00'Vette's Avatar
00'Vette
16.0:1 compression is not going to run with 93 octane fuel........well it may run, but it'll detonate like a ***** fu#ker!
I want to see a big bore (500+ ci) LSX motor (or warhawk block) built to run on pump gas and see how well it performs.
You know they'll make one with a$$loads of tourque. And torque my freinds wins races.
Old Dec 19, 2006 | 01:06 AM
NSTG8R's Avatar
NSTG8R
depends on what race you're running buddy.
Old Dec 19, 2006 | 01:38 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Now that is the direction I am going with this ulitmate bad boy GM PERFORMANCE LSX indestrucable iron block. Figure a perfectly square motor with 4.25 overbore and 4.25 stroke makes for a beatiful 482 cubes and with some killer LS7 heads and a great street/strip cam, making a pump gas friendly 11:25 to 1 compression, 650 rwhp NATURALLY ASPIRATED, should be no problem. COuld you imagie that TORQUE!!
Old Dec 19, 2006 | 01:07 PM
00'Vette's Avatar
00'Vette
True...........true!
Old Dec 19, 2006 | 05:57 PM
tlaselva's Avatar
tlaselva
Why stop there?
You forgot to add a Kenne on it!
If 447ci is good, 482ci must be better!
Old Dec 19, 2006 | 06:54 PM
jkz06's Avatar
jkz06
I just want to hear that monster idle.
Old Dec 19, 2006 | 07:00 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
To When a 427 is NOT ENOUGH??
Old Dec 19, 2006 | 10:09 PM
cruisemon's Avatar
cruisemon
16:1 and 0.900 lift. Truly remarkable. The geometry of the cam, rockers, rocker ratio, rod length, etc., must have been especially challenging. What can you share with us about cam timing, LSA, etc., and especially cam duration at 0.050 lift?
Charlie
Old Dec 19, 2006 | 10:57 PM
Crabr1's Avatar
Crabr1
Any idea what it will cost to build an engine like this.
Old Dec 20, 2006 | 12:13 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you know at some point you should just run the engine to a propeller in the front, add wings and never worry about traffic jams again....
machine guns are optional and those of you with navigations systems will find them perfectly useless.
