Security Light Comes On.......
Old Dec 19, 2006 | 01:45 PM
NJ Vette Guy's Avatar
NJ Vette Guy
Default Security Light Comes On.......
While I was driving, my "security" light, lit up.....
Since I was on my street, I stopped, turned off the car, opened and closed my door clicked the fob and restarted the car. The light went off and while I was driving, it came back on again.
When I got to my destination, I turned off the car. When I came back out an hour later, I pressed the fob, got in and the car wouldn't start. All of the electrical features worked (windows, radio, etc.) but when I turned the key, there was no power to the ignition.... No clicking either, like a bad starter, just no applied power to the starter.
I turned the wheel a little bit (The CLB was done to my car before I bought it) and still nothing. There was no DIC message either. Finally, I removed the key, waited a few seconds, clicked the "unlock" button on the fob a few times, reinserted the key and thankfully, it started right up.
What would cause that to happen?
The battery is new (replaced it in August) and since this happened today, I turned the car on and off a few times and it starts...... But still, I worry.
Any insight would be appreciated.......
Old Dec 19, 2006 | 09:54 PM
oldschoolvette's Avatar
oldschoolvette
Welcome to the club. If you search for this topic you will find much data. It could be the chip in the key, the reader in the switch or C5 grimlin. My bet is that the key is damaged, they are sensitive, Good luck and use the search feature at the top of the page to find more data
Old Dec 20, 2006 | 12:21 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
The C5 gremlin in this case would be the BCM, after you clean the key pellet with rubbing alcohol and you are still having an issue, check to make sure that your BCM connections are tight and clean. Look for signs of water hopefully, your AC drain isn’t plugged and leaking unto the BCM.
Old Dec 20, 2006 | 12:37 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My 98 MN6 coupe had a simular issue. Mine would also not start and once it did, it would DIE on the side of the highway!!!!
Long story short,,,it was being caused by bad grounds and a corroded BCM. Mt BCM got wet because my HVAC Drains clogged and let moisture enter the passengers foot well.
Check G-101, 102, 104/108. see if they are clean and secure. Also check to see if the BCM and or the passengers foot well has been wetted.
BC
Old Dec 24, 2006 | 10:33 AM
NJ Vette Guy
Thanks for the help, guys.....
A quick wipe of the key chip did the trick.....
Old Dec 24, 2006 | 10:37 AM
proracr's Avatar
proracr
Something that really irritates me is that whoever did the programming for the security system made a major mistake. When one inserts the key that came from the factory with the car into the ignition switch and starts the car, the computer should NOT assume that the car is being stolen. 99 times out of 100 a thief would not have the keys to the car. Come on GM, you can do better than that! Our car has the memory function and every time I have to "Remove the key and wait 10 seconds" my mirrors and seat get unnecessary wear and tear. I would like to b.... slap the engineer(s) responsible for this every time it occurs.
To Security Light Comes On.......
