HELP! Rough idle after spark plug/wires replacement...
Old Dec 23, 2006 | 08:47 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Bill has covered this post well, In the future a laser temp gun also works very well in troubleshooting a misfire
just shoot the header tubes 1,3,5,7 2,4,6,8, you'll see the misfire cyl. down about a 100 degrees
http://www.raytek-northamerica.com/c...l?cat_id=2.3.5
I've found the oem GM wire(packards usually) tend to come apart on the plug end easily, In '04 GM went to a red wire, I believe this is the same one used from the GMPP catalog
Old Dec 23, 2006 | 01:14 PM
z06inVB's Avatar
z06inVB
Thought I might throw this one out there in case any one does a search on this. I had a similar problem with a mis fire after changing the plugs. Only mine would mis fire only under load but the idle was smooth. Over a couple hours it got worse but still only under load. Basically you could drop it into 4th at 30 go to WOT and the thing would go crazy.
Turns out it was owner induced. I simply had not tightened plug number 3 and that was the cause. So if all else fails check the plugs to make sure you tightened them!
Old Dec 23, 2006 | 02:22 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
If I had to guess I'd say you damaged the plugs during install, I wouldn't bother trying to get a refund. Same on the O2 sensor, you didn't need it, but it's used now.
Lessons learned, profit from them in the future.
Old Dec 23, 2006 | 02:35 PM
vettenuts's Avatar
vettenuts
And save the O2 you removed, you can always re-install later. I did the same thing chasing a rich code and kept the old one.
Old Jan 7, 2007 | 12:49 AM
c5wolf's Avatar
c5wolf
any update
