Cam Install question
Old Dec 22, 2006 | 11:05 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Default Cam Install question
When changing a cam in a vette a person said that I have to "drop the engine out of the cradle" to do the install because
1. It will be twice the work if I dont
2. I will mess up some of the sensors if I don't.
From what I read I don't see any instructions that mention dopping the engine to do the install. Does the engine need to be dropped or is this just overkill.
Old Dec 22, 2006 | 11:14 AM
gonbad's Avatar
gonbad
No. Look at LS1howto.com. Look at the C5 head and cam install.
You don't have to drop the engine or remove the heads. It is a lot of work either way.
I changed mine in 2004 in the car.
Some tuners will drop the motor because its easier to get to things that way.
Old Dec 22, 2006 | 11:20 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
what are you up to weasel??? I want full schematics...
Old Dec 22, 2006 | 11:42 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
If I had to guess I'd say it was April Fool's, but my calendar says it's still December.
Of course you don't drop the motor for a cam swap, you drop the mechanic suggesting it.
Old Dec 22, 2006 | 12:18 PM
vettenuts's Avatar
vettenuts
Did mine in the car alone, dropped a couple of wrenches but no motor
Old Dec 22, 2006 | 02:07 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
The ones that do have a lift and the means.
Old Dec 22, 2006 | 04:13 PM
Wicked Weasel
thanks guys. I think it is someone that just likes to stir things up.
http://forums.corvetteforum.com/show...1575328&page=2
Originally Posted by MEATHEAD
As I said just my two pennys worth, but from the looks of it your a ace mechanic. I bet you turn your on wrench on your car. I have over 20 yrs. From race bikes to cars . I guess you know that anything that comes from the factory is not all polished like sand cast on the MAFS and throttle body. Thermostat what part of the world do you live in, I know that it gets over 100 deg where I live. Timing chain U are right use the old one lololol. And the oil pumps don't come polished. You need to get your facts right. Try doing a cam swap on vette without droping engine out of the cradle. It can be done if you like twice the work and messing up some sensors on the car.
Ps Do you even have a vette I see that your profile lacks that info.
Old Dec 22, 2006 | 05:58 PM
Dan_the_C5_Man
Merry Xmas! http://forums.corvetteforum.com/show...15705&posted=1
Old Dec 23, 2006 | 02:42 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
I thought you were trying to play catch up!
Really though, where do people get this idea???
Old Dec 23, 2006 | 08:48 AM
vettenuts's Avatar
vettenuts
The book that the poster references for engine removal actually does recommend removing the entire driver train to change the cam. Might be easier with all the tools/lifts/drive train cradles, but for the average Joe trying to do this in the garage its not.
Old Dec 23, 2006 | 08:54 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I've read some members dropping the cradle only a few inches if not electing to remove the p/s rack
I've seen a lot of information in the books to be inefficient, I choose to leave the A/C and brake systems unopened and with the body
Old Dec 23, 2006 | 09:55 AM
Wicked Weasel
there has been thoughts to see how the ECS cam would work with the AFR heads....
Old Dec 23, 2006 | 09:35 PM
sams96's Avatar
sams96
With the car on jack stands you can support the motor with a jack stand. and lower the x-member to get to the crank pulley. I think its a lot cleaner because you don't have rack fluid all over the place.
Old Dec 23, 2006 | 09:47 PM
vettes4fun's Avatar
vettes4fun
Old Dec 23, 2006 | 09:54 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Done it three times and never dropped anything, except alot of tools and some fluids.
Old Dec 23, 2006 | 10:10 PM
402Sam's Avatar
402Sam
Heck, for a cam swap the heads dont even need to come off of the motor... Hardest part is moving the steering rack.
Old Dec 24, 2006 | 12:15 AM
GeorgeZNJ's Avatar
GeorgeZNJ
did you like my response?
Old Dec 24, 2006 | 12:17 AM
GeorgeZNJ's Avatar
GeorgeZNJ
If they need a test mule, I need heads at a test mule price.
Old Dec 24, 2006 | 07:09 AM
oldschoolvette's Avatar
oldschoolvette
drop ps rack good luck
To Cam Install question
