Clutch job $
Old Dec 27, 2006 | 02:08 AM
midnightc5's Avatar
midnightc5
Default Clutch job $
Can someone clue me in as to how a clutch
replacement would cost? I know i'll need one
in the near future. Just want to get an idea.
Thanks, Tom
Old Dec 27, 2006 | 02:37 AM
mdhmi's Avatar
mdhmi
Labor is around $600-850. The clutch itself is anywhere from $400 to several thousand.
Old Dec 27, 2006 | 10:34 AM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I sell the LS7 clutch, pressure plate and flywheel for 398.05. You can get a new slave and master for about 250.
Thanks,
Gene
Old Dec 27, 2006 | 12:47 PM
vince3's Avatar
vince3
400-500$
Old Dec 27, 2006 | 02:10 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Going for the lowest cost is not usually a good move so make sure whoever does this can and will guarantee your satifaction and stands accountable for poor results.
I'd expect to pay $500-$650 labor and I would expect to have zero issues, no leaks, no vibrations, nothing but smoooth clutch engagement at the proper pedal loaction.
I also think the car needs to be re-aligned - add another $80-$125
Old Dec 27, 2006 | 03:15 PM
jmzvet's Avatar
jmzvet
A shop in SoCal said $650 for labor which is about the going rate around here. I have LT headers so it might be a little cheaper if you don't.
Old Dec 27, 2006 | 03:16 PM
jmzvet's Avatar
jmzvet
Why would an alignment be necessary?
Old Dec 27, 2006 | 03:25 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
because your dropping the rear xmember and relying on the dowel pins for alignment upon installation
I believe this is also in accordance with the GM instructions
Old Dec 27, 2006 | 07:39 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I've heard anywhere from $600 to $800. LG did my brothers and no alignment was needed.
Old Dec 28, 2006 | 12:39 AM
midnightc5's Avatar
midnightc5
Thanks guys! Although hefty...not as bad as I
thought.
Old Dec 28, 2006 | 07:43 PM
jmzvet's Avatar
jmzvet
Good info.
Old Dec 28, 2006 | 08:45 PM
Jeffs FRC's Avatar
Jeffs FRC
I cant see any reason for an alignment.
The dowel pins on my car didn't magically move while the car was apart for the clutch install.
To Clutch job $
