Battery Problems
Old Dec 27, 2006 | 06:47 PM
Rclynch82's Avatar
Rclynch82
Default Battery Problems
So Ive had my 98 Coupe now for about 3 months (my first vette ) and I have my first problem. About 3 weeks ago I started having to jumpstart it cause my battery was dead when the car would sit for more than 8 hours. The longer the car sits the less power it has. seems to me like something is draining power. I replaced the DieHard Gold with a Optima Yellow Top but I still have same problem. I think my Alternator is on its way out but I drive 75 miles per day and it should have died by now if it were bad. Ive checked all interior lights and so on for the obvious, any one have a clue. thanks in advance for the help.
Ryan
Old Dec 27, 2006 | 06:58 PM
Dave68's Avatar
Dave68
What does the D.I.C. display for battery voltage while you are driving? If you fully charge your battery and then don't drive for a day, is the battery discharged? If so, it's not the alternator that's at fault.
Old Dec 27, 2006 | 08:08 PM
Rclynch82's Avatar
Rclynch82
When Im driving my volts are fine. It reads between 12 and 13. I think the alternator is recharging the battery b/c the car will start just not when left for like 8+ hours. I also checked power seat switches and they were fine. I will buy a meter tomorrow and see if I can find a draw.
Thank you
Old Dec 27, 2006 | 08:20 PM
thehammer69's Avatar
thehammer69
Thank you
It should read between 13 and 14. I think your alternator is weak.
Hammer
Old Dec 27, 2006 | 08:45 PM
Bill Dearborn's Avatar
Bill Dearborn
Hammer
Normal voltage when the alternator is running is 13.8 volts. After start up it can up to 14.3 for a short while before dropping back to 13.8.
Bill
Old Dec 31, 2006 | 04:07 PM
2wdchevy's Avatar
2wdchevy
Default battery keeps dying
I have a 98 Vert with about 50K miles and I to have had the same problem. I have owned the car a little over a year and have already taken it in a couple times to get it checked and everytime they say the alternator and battery are fine. Well, 2 weeks ago i bought a brand new battery for it and this morning it wont start. No keyless, not even any lights on. This car is a daily driver as well and was just driven yesterday. Volts are fine when car is driving. I am very irritated as I know you are. Hope to take it back to the chevy dealership tomorrow so if I find anything out Ill let you know (thank god i bought the extended warranty). Might be time for me to get a truck....
Old Dec 31, 2006 | 04:48 PM
bob guzzy's Avatar
bob guzzy
Default dead battery
Sounds like something is staying on, take a test light and take the negitive cable off, and clip the test light ground, wire to the cable, then put the probe end on the battery terminal, if you see a light you have an obvious draw, make sure the doors have been closed and the timer for the interior lights, went off before disconnecting the battery.
You have to disconnect the hood light, also, now if you see a light or a dim light you have a draw, you can track down the draw by removing fuses one at a time untill the light go's out(test light), that will narrow it down to a particular circut, then eliminate each thing in that circut untill you find it....
Old Dec 31, 2006 | 05:31 PM
Red903L's Avatar
Red903L
Originally Posted by bob guzzy
Sounds like something is staying on ....
...but unfortunately I don't have a cure for you!
As a suggestion, you might take a look at the thread named "IMPORTANT ELECTRICAL INFORMATION" at the beginning of this forum section. It might be of some help..
Good Luck....
Old Jan 1, 2007 | 01:45 AM
oby1's Avatar
oby1
And just a side note. I had the same issue with my 99. Bought a red top and about 2 months later had the same issue. Parts store told me the battery was OK but I convinced them to replace it. I have been good now for over a year.
The link above also helped me with the c5 electrical gremlins. Mostly sporadic stuff that was just dirty grounding points.
Old Jan 1, 2007 | 06:22 PM
PaiN00FRC's Avatar
PaiN00FRC
Ryan
Hi Ryan,
first let me just start by saying I went through the EXACT same experience with my 00'FRC.
Definately something (or THINGS) are draining the power. First I would do is read through Bill Curlee's sticky post on electrical gremlins.
Then look at his thread here...
http://forums.corvetteforum.com/show...23&postcount=7
It has pics that detail how to correctly wire in an ampmeter to test how much draw is on your system when things power down.
When you turn the key off, and close the door it takes several minutes for the various systems to shut down, but you will always have a small amount of draw, keyword being small.
I used the setup described by Bill, and isolated two seperate problems. 1) a bad altenator.... the integrated voltage regulator was bad and had to be replaced. 2) an improperly wired window swith that was drawing current at all times.
I fixed these problems, added a new battery, and glad to say...my car has gone several months in the garage with no change in batery power.
Good luck
Larry
To Battery Problems
