Transmission shot?
Old Dec 27, 2006 | 09:23 PM
LW97Vette's Avatar
LW97Vette
Default Transmission shot?
I hope someone can help me. Tonight I was backing out of my driveway, put the car in drive, and it kept going backward. I put the car in other gears and it still continued backward. So I guess the transmission broke in reverse gear? Also the shifter "slides" up & down without stopping at any particular gear. If it is shot, what am I looking at in repair cost?
Your feedback is much appreciated.
Thanks,
John
Is the selector control cable a part on an automatic transmission & if it is, can it be fixed by someone with limited transmission knowledge?
Thanks,
John
Old Dec 27, 2006 | 09:25 PM
Blowndave's Avatar
Blowndave
sounds like the selector cable has popped off. i think your trans is fine! lift up the vehicle and manualy (on the side of the trans case) go through the gears. chances are you have a popped off/broke cable or a bad shifter.
Old Dec 27, 2006 | 09:26 PM
jbauch357's Avatar
jbauch357
Old Dec 27, 2006 | 09:28 PM
widewheel's Avatar
widewheel
It's possible that the cable from the shift lever to the transmission has either borken or become unattached. It's just a guess though.
Old Dec 27, 2006 | 09:38 PM
LW97Vette's Avatar
LW97Vette
Thanks BlownDave, I hope you're right. I feel much better now.
John
Old Dec 27, 2006 | 10:30 PM
Blowndave's Avatar
Blowndave
John
anytime
Old Dec 28, 2006 | 12:53 AM
LW97Vette's Avatar
LW97Vette
Thanks,
John
P[B]S--Is the selector control cable a part on an automatic transmission & if it is, can it be fixed by someone with limited transmission knowledge?
[/B]
Thanks,
John
Old Dec 28, 2006 | 08:09 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I doubt your trans is shot, I agree with everyone else in saying the cable that connects the shifter to the trans is either broke or disconnected.
Old Dec 28, 2006 | 09:24 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
people, there is not a 'cable' on the C5's, there is a linkage rod
John, It would be a good idea to remove the console and make sure the basics are together properly, I have never seen the problem you are describing, but would think 'effort needed' would be noticeably reduced
I will tell you I have seen aftermarket shifters installed with the bolts backed out after a few hundred miles, this could be the cause of your problem
Old Dec 28, 2006 | 10:09 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
On C5's with an automatic transmission there is a cable that connects the shifter and transmission, on C5's with a manual trans there is a shifter rod (solid piece) that connects the shifter and trans.
I was just assuming he had an automatic by his description of the shifter sliding up and down without stopping at any gear.
Old Dec 28, 2006 | 12:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
AUTOMATIC or MANUAL????????????
Old Dec 28, 2006 | 02:49 PM
Bill Dearborn's Avatar
Bill Dearborn
Its an auto. He clearly says he put it in drive in his write up.
Bill
Old Dec 28, 2006 | 07:40 PM
widewheel's Avatar
widewheel
Bill
Old Jan 2, 2007 | 01:12 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
The selector control cable fell off on my 98 A4. It also would not start beause the trans was not in park or neutral. Call Gene at GMpartshouse.com
To Transmission shot?
