Tranny/Diff Oil...
Old Dec 27, 2006 | 10:46 PM
Corvette Don's Avatar
Corvette Don
Default Tranny/Diff Oil...
I tried to do a search on this but I got my vette yesterday and put Royal purple oil in it today, I want to change the (mn6) tranny and diff fluids to royal purple too, question is what royal purple stuff do I use?? and how much?? Syncromax? Royal purple atf? I know the diff needs a limited slip additive but dosent the royal purple already have it?? Thanks
Old Dec 27, 2006 | 11:46 PM
Brad@RevXtremeAutoSports's Avatar
Depending on the year, you need to be careful on which trans fluid you use. 97, 98, 99 and maybe 2000 (someone correct me here on the end year) use paper blockers in the trans, and synthetic oils will break the blockers down and mess up the tranny, unless it has been rebuilt.
Good info here ------> http://forums.corvetteforum.com/show...erential+fluid
Old Dec 28, 2006 | 12:03 AM
Corvette Don
So I would use royal purple sycromax in the tranny INSTEAD of royal purple ATF IF I do have the paper blockers??? And for the diff I guess I put the recommended weight of gear oil in there (royal purple max gear oil), just want to make sure that stuff has the limited slip additive and is ok to use. I have a 2000 coupe so i dont know if i have the paper ones or not
Old Dec 28, 2006 | 09:49 AM
Corvette Don
No one on this? I plan on doing it later today...
Old Dec 28, 2006 | 09:59 AM
Diff
C & P : Many opinions here as well about the best fluid and correct amount as it regards the well documented left side seepage. I went with Royal Purple 75/90 because it has LSD additive and it's about $10 per quart versus $28 per quart for the GM plus $4 for the additive. The Royal Purple users also gave the best reviews. Now for the amount.....
1.69 quarts plus 4 oz additive equals 58.08 ounces. I used a nylon hose on a graduated 8 oz squeeze bottle and put in exactly 58 ounces cold. This put the level about 1/4 inch below the fill port, corresponding to the belief that it should reach the fill level only when hot.
Tranny
Manual trans fluid: Leveled car, then drained 3 1/2 quarts. Raised front for an aft rake and drained another 1/4 quart. Aprox 1/4 qt of 4.1 total is inaccessable in trans cooler.
Lot's of discussion about the best fluid here....I was concerned about the paper ring blocker filters and thier reaction to synthetics so I went with GM's latest ATF: Dexron VI. This is recommended to replace all Dexron III applications.
You wont go wrong with the GM stuff.
Good Luck
Update: I have some contacts and spoke directly to Jared who is lead prudcuct development at Royal Purple, he states "that the synchromax is fully compatible with all c5 standard transmissions. He further states that RP is not alcohol based, and that the synthetics that are can casue those breakdowns (paper blockers)to occur"
I asked him if he was sure and not just trying to increase sales his reply was that in 8 years he has been there he has not seen or heard one c5 related tranny issue with syncramax. He is not willing to risk a 3000.00 transmission over a 50.00 sale and the litigation. He stands behind his product.
Good luck with your decision.
Old Dec 28, 2006 | 10:26 AM
Corvette Don
Ok thanks for that, in my owners manual its says to use dextron III ATF and so does the label on the tranny, SO my question now is would I use royal purple sycromax OR royal purple MAX ATF. Thanks for the help
Old Dec 28, 2006 | 10:59 AM
rws.1's Avatar
rws.1
I could not find the RP Syncromax locally so I put RP ATF in...
It is fine..... after 15K miles.
Old Dec 28, 2006 | 11:59 AM
Corvette Don
So its ok to put sycromax in or should i put the atf stuff in???
Old Dec 28, 2006 | 03:06 PM
Corvette Don
Anyone?
Old Dec 28, 2006 | 06:36 PM
Corvette Don
Ok I put royal purple max ATF in, but it only took 3.1 qts.
To Tranny/Diff Oil...
