Cracked Block on my 03 C5
Old Dec 27, 2006 | 11:14 PM
mikes72's Avatar
mikes72
Default Cracked Block on my 03 C5
Driving normal I noted temp raising t 230 which it never did before. Pulling over I checked all and found coolant low but no leaks, so I added water to finish my way home. Restarted car and it ran fine no lights and temp went down to normal. Stopped off for gas and noted temp raising again. 5 miles later got home and noted the coolant low again. Checked oil and I have intermix. Running fine except for the temp getting up to 230. So now with 42k on the engine, I drive her daily, I'm towed in to the dealer to find problem. No codes. No sign of overheat except intermix. I give permission to tear down. Teardown showed no wash on pistons and no sign of blown headgasket. Closer inspection showed a crack on the top of the block between 2 and 4 but not in the cylinder wall only on the top of block. I have requested assist from Chevy and they are to send out rep to look at. How rare is this crack??
Anyone heard of this problem??
Old Dec 28, 2006 | 12:14 AM
mdhmi's Avatar
mdhmi
Damn that's a pisser. On the bright side a new block is under a grand.
Old Dec 28, 2006 | 10:46 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
This is the first time I've heard of a crack between the cylinders, most of the time the cylinder wall itself cracks.
Old Dec 28, 2006 | 12:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks like a re-sleve to a 402 !! While shes apart, bullet proof the bottom end! If it were on my tab,,thats what I would do!
Old Dec 28, 2006 | 01:04 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Very very rare w/o nitrous use or forced induction. If GM doesn't help you out I'd say it's time to call one of the great tuners on the forum and get something like a 402 in the car.
Old Dec 28, 2006 | 01:27 PM
vette dan's Avatar
vette dan
Vette Dan
Very rare. When my 2004 with 27K on it blew the crank out GM put in a new engine. It was covered under my GMPP. New engine $8715.05
If it would have been my nickel I could have a heck of an engine for that money.
Old Dec 28, 2006 | 02:53 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If it's cracked across the top of the block between 2 cylinders then the only reseleeve that will work will be the Darton M.I.D process.
Old Dec 28, 2006 | 04:25 PM
RonVette2's Avatar
RonVette2
Old Dec 28, 2006 | 08:35 PM
Howard Wolf's Avatar
Howard Wolf
If you're considering using the Darton MID kit to
resleeve your block and want to see what it would
look like, email me at lcwolf03@comcast.net and
I'll reply with a picture of one. I also have a 6 page
list of FAQ's regarding wet sleeves if you're
interested.
To Cracked Block on my 03 C5
