Which Headers?
Old Dec 29, 2006 | 08:21 AM
rws.1's Avatar
rws.1
Default Which Headers?
Kooks?
LG Streets?
American Racing?
Dynamaxx?
StainlessSteel Works?
I'm dizzy with the offers...
What is your opinion on which one is best for the C5. Best to me means
a combination of HP, torque, direct bolt on fit, longevity and price.
Old Dec 29, 2006 | 12:45 PM
BarneyZ's Avatar
BarneyZ
FWW My installer told me that the Dynamax's are MUCH easier to install and that their heavy flanged connectors are much better/reliable than the "slip fit" style used on the LG's, which, some say. makes them prone to exhaust leaks.
Old Dec 29, 2006 | 01:40 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I have run a few different brands, IMHO the LG's are by far the the best all around. Very simple install, as well as great power both at a great price. I love mine
Old Dec 29, 2006 | 02:44 PM
Jay's Z's Avatar
Jay's Z
LG Pros. See siggy...
Old Dec 29, 2006 | 02:46 PM
wayneinvirginia's Avatar
wayneinvirginia
Cruise-In VIII Veteran
Love my Dynamaxx system. I like the fact that for one price I got the headers, cats, and x pipe. The shop that installed them for me said they were the best fitting set of C5 headers they had ever installed.
Old Dec 29, 2006 | 02:47 PM
redcycle13's Avatar
redcycle13
I installed the LG Streets myself. Very easy project, no leaks, great performance. I also installed a set that had bolt together flanges, and they were much harder to install. Getting the flanges lined up was a pain.
Old Dec 29, 2006 | 02:50 PM
vettenuts's Avatar
vettenuts
Of all the headers I see listed, have you considered a Tri-Y design? I am running the QTP's, only all stainless Tri-Y design for the C5, which uses Random Tech cats and "X" pipe. They are also easy to install.
Popular Hotrodding Article on Jack Burns Header Design
Old Dec 29, 2006 | 03:31 PM
rws.1's Avatar
rws.1
Vettenuts... thanks for the link. Interesting article... where did you get your QTP's?
I need to learn more about them
Old Dec 29, 2006 | 03:36 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Should have my ARH next week.
Old Dec 29, 2006 | 03:48 PM
keanucosmo's Avatar
keanucosmo
Bassani also makes Tri-Y's, although they are ceramic coated, not stainless.
Old Dec 29, 2006 | 04:36 PM
bcseitz's Avatar
bcseitz
Don't even consider Stainless Works.
Had one header that didn't fit. The right front 02 was shoved right up against the bell housing tunnel. I even had the pipes pryed over, tightend, then tac welded here and there to secure. That still didn't hold.
Had their rep. out to look at it. Get this, he said the best thing to do was mash the floor in to make room for the 02 sensor!
Stainless Works won't replace the header.
How's that for crappy customer service!
Old Dec 29, 2006 | 06:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I have TPIS on at the moment, but I ordered the American Racing Headers on the Dec special and they will be going in when I do the clutch that got fryed at the track, and then I will be able to see if they will gain me some rwhp
Old Dec 29, 2006 | 06:32 PM
vettenuts's Avatar
vettenuts
Straight from Barry at QTP, forum vendor
OH, and of course this little gem bolts right in
Cutouts
Old Dec 29, 2006 | 08:27 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Old Dec 29, 2006 | 09:17 PM
nuke61's Avatar
nuke61
Another vote for Dynamaxx... great fit, easy to install, and absolutely no leaks. Every part you need for the install is included in the kit, and did I mention no leaks?
With just about every other header out there I've read about someone having problems with leaks or the AIR tube breaks off, but I've never read about any problems with leaks or AIR tube breakage on the Dynamaxx headers. That's why I ended up buying and installing them.
Old Dec 30, 2006 | 12:22 AM
vettes4fun's Avatar
vettes4fun
We have installed both LG and Dynamaxx at the shop both are great fitting headers. I think the largest dirrerents is that the Dynamaxx as a 2 1/2in x-pipe and the LG as a 3in x-pipe. bigger pipe better flow but since your mufflers are 2 1/2in I don't see much use in the 3in x-pipe on most motors.
Old Dec 30, 2006 | 06:02 AM
Dynatech SuperMaxx system seems to be very good. A number of forum members have posted very positive comments about them and the two tuners that I have spoken to about them state they are very good.
To Which Headers?
Old Dec 30, 2006 | 07:52 AM
vettenuts's Avatar
vettenuts
I think the advantage with the 3" system is by the time the exhaust is to the mufflers it has cooled considerably and doesn't need the larger diameter.
Old Dec 30, 2006 | 08:53 AM
Carmen@TheVetteDoctors's Avatar
0Carmen@TheVetteDoctors
Former Vendor
From: Amityville 2010 & 2011 NMCA Late Model EFI Champions BEST Service & the BEST prices on the EastCoast
AmericanRacing/VetteDoctors
TheBetterHeader
Old Dec 30, 2006 | 09:06 AM
Webz's Avatar
Webz
Default "Other" vote for Melrose Headers
Engineered by the same team who produced the headers for the LS-1 spec engines that went into every ASA racecar.
http://www.melroseheaders.com/produc..._flow_headers/
