DRL's - Canada Car
Old Dec 31, 2006 | 01:20 PM
Corvette Don's Avatar
Corvette Don
Default DRL's - Canada Car
I bought my 00 coupe in florida but I am pretty sure its a canada car since I can turn off the Drl's, is there ANY way to prevent the headlights from coming on when its getting dark out, I want to be able to control that myself.
Old Dec 31, 2006 | 01:25 PM
Kale's Avatar
Kale
Hit the OPTIONS button, its in that menu. I think 'twilight sentinel'
Old Dec 31, 2006 | 01:27 PM
Corvette Don
There is no "on, off" option in that part cause its a canada car. There has to be a way to bypass that
Old Jan 1, 2007 | 02:41 PM
tlaselva's Avatar
tlaselva
Cant' remember if it's fuse # 44 or # 40. It's a rectangular grey fuse with 4 prongs. Pull it out, and it'll disable the auto headlights.
Old Jan 1, 2007 | 11:56 PM
Russ K's Avatar
Russ K
Since I'm from Canada, I had to use a Tech II to set up the BCM to allow the auto headlamps to be turned off using the DIC.
Russ Kemp
Old Jan 2, 2007 | 03:34 AM
DeeGee's Avatar
DeeGee
Being able to turn the DRLs on and off is news to me.
The DRL mod can be done in 2 ways. Pull the A2 fuse which turns off the DRLs but leaves a few DIC codes and affects the approach lights function. Simple and reversible.
The permanent mod is to pull the 2 relays (40 and 44) in the pax footwell. You then need to fit a couple of jumper cables to return the lights to normal operation. Its documented in a Tech Tip.
With a US spec Twilight Sentinel can be turned off via the DIC. If its a Canadian spec car it's permanently live and can't be deselected. As Russ says, a reflash is the solution.
I think the 300 kph speedometer is the big give away in identifying a Canadian spec car. That and the RPO codes.
Old Jan 2, 2007 | 10:59 PM
Corvette Don
Any idea where I can find the tech tip/or how to run the jumper wires??
Old Jan 3, 2007 | 12:22 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I pulled the #44 fuse so my headlights dont come on automatically everytime I come out of the garage.
Old Jan 3, 2007 | 02:44 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
https://www.corvetteforum.com/techti...=273&TopicID=1
To DRL's - Canada Car
