Rear O2 simms
Old Jan 2, 2007 | 10:20 AM
oldschoolvette's Avatar
oldschoolvette
Default Rear O2 simms
(98 vert) Has anyone had a problem with the car throwing P0160 'bank 2 sensor 2 inefficiency' with the simms installed or is my simm going bad? It only does it about once a week, normally w/in first couple of miles. once reset it doesnt come back. thanks
Old Jan 2, 2007 | 10:27 AM
BlueDragon's Avatar
BlueDragon
Yep-er I did. I think it was moisture in the connector or something. I swapped the Simms to see if the problem would go with the Simm and what do you know it went away completely!
But at the same time I had a battery go bad along with a oil pressure sending unit. So I don't know if the O2 sensor and Oil Pressure sending unit were caused or were affected by the bad battery or not but they all happened within a few days of each other.
This car has gone years between problems then bingo I get three within a couple of days. Replaced the battery and OP sender and swapped the Simms and everything back to normal.
Old Jan 2, 2007 | 10:30 AM
oldschoolvette
thanks now that you mention it it does seem to happen after rain maybe I need to check the connector and tape it up.
To Rear O2 simms
