Headlight Door Closing
Old Jan 9, 2007 | 09:47 PM
peptoy's Avatar
peptoy
Default Headlight Door Closing
I have a 98 that I just replaced the headlight switch on. Now when you turn the headlights on, both pop up correctly. When you turn the headlights off, the pass side closes, and then tries to keep closing after it bottoms out for about 5 sec.
Is there an adjustment, or did the headlight control module also go bad?
Thanks in advance.
Old Jan 9, 2007 | 09:54 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Put a rebuild kit into the headlamp motor for that side. The rubber bushings inside have probably come apart. You can also just replace the motor assembly at a higher cost of course.
Old Jan 10, 2007 | 05:05 PM
peptoy's Avatar
peptoy
Thanks for the reply. I'll get it done.
Old Jan 10, 2007 | 07:33 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
http://www.rodneydickman.com/retail_new.html
under electrical
To Headlight Door Closing
