Please help... Anyone know what these codes mean???
Old Jan 10, 2007 | 01:55 AM
Jhyten's Avatar
Jhyten
Default Please help... Anyone know what these codes mean???
I just pulled some codes from my car and was wondering if anyone can tell me what they mean and if i need to fix anything. Thanks guys!
28-tcs c1282 h
58-sdm b1000 h
60-ipc b0521 h
ao-ldcm b2282 h, u1064 h
a1-rdcm b2283 h, u1064 h
bo-rfa c2100 h
bo-rfa c2110 h c
Thanks for anyones help!
jake
Old Jan 10, 2007 | 02:23 AM
hrcantrell's Avatar
hrcantrell
Default Codes
I am far from an expert but the information sheet I have says that anything that ends with an H is a history code and is not a current problem. Hopefully someone with more knowledge will answer you shortly. Harold
Old Jan 10, 2007 | 03:16 AM
Ducati749's Avatar
Ducati749
28-tcs c1282 h: Yaw Rate Sensor Bias Circuit Malfunction
58-sdm b1000 h: ECU Malfunction
60-ipc b0521 h: Tachometer Signal Circuit Malfunction
ao-ldcm b2282 h: Battery 1 or Battery 2 Voltage Out of Range
u1064 h: Lost Communication with BCM
a1-rdcm b2283 h: Battery 1 or Battery 2 Voltage Out of Range
bo-rfa c2100 h: Left Front TPM Sensor Malfunction
bo-rfa c2110 h c: C2110 Right Rear TPM Sensor Malfunction
Source C5 computer codes: http://www.corvettedoctor.com/Code_Main.html
Best thing now is to erase all the codes, and drive around for a while in order to generate a recent list of codes...A weak battery is known to cause random codes to be thrown. Looks like your only concern is to check your tire pressure sensors, or your car battery. hopefully it's as simple as batteries. For some reason though, i feel it wouldn't label it as a sensor malfunction if it was the sensor battery, but not sure of that....Hope this helps
-Chris
Here is another great code site:http://www.innernet.net/mdcc/c5secrets.html
To Please help... Anyone know what these codes mean???
