torque specs!
Old Jan 10, 2007 | 03:35 PM
dwarmenzerk's Avatar
dwarmenzerk
Default torque specs!
hey guys I had to replace my alternator bracket. 99 a4 coupe
If someone could give me the torque specs on these items
throttle body bolts
idler pulley
powersteering pulley
powersteering pump bolts
alternator bracket bolts
thanks guys..
and i did a search for a comprehensive set of torque specs, couldnt find one..
Old Jan 10, 2007 | 03:39 PM
Oldvetter's Avatar
Oldvetter
Send me a PM with your email address, I will send you a copy of them.
throttle body bolts = 106 IN-lbs
idler pulley= 50 ft-lbs
powersteering pulley = ?
powersteering pump bolts = 25 ft-lbs
alternator bracket bolts = 50 ft-lbs
Old Jan 10, 2007 | 03:46 PM
zeevette's Avatar
zeevette
None of those items listed are particularly sensitive to torque numbers. Just get 'em tight. The TB uses a rubber gasket, so as long as it's tight enough to seal OK, it's good.
Old Jan 10, 2007 | 04:29 PM
ICUALL's Avatar
ICUALL
Default specs
http://www.cccorvetteclub.org/C5_Torque_Values.pdf
To torque specs!
