High Air Temp
Old Jan 11, 2007 | 10:36 AM
B-rent's Avatar
B-rent
Default High Air Temp
I recently had my mechanic do some work on my car and when he scanned it he noticed I was running about 180 degrees from the intake. It is supercharged, with a blackwing and LS6 manifold and I had just been getting on it a little bit, but he still said it was high. Any ideas?
I do still have the spoiler on the front and the hood seal so I dont think Im missing anything really.
Old Jan 11, 2007 | 11:18 AM
MRCoupe2002's Avatar
MRCoupe2002
I'm not running a supercharger, but I do have a Blackwing and the hood seal as well. Last year, I was running at the track while scanning and found that I was hitting 160+ intake temps and only getting back down to about 120 degrees at the end of the run. This was resulting in the engine pulling a lot of timing advance in an attempt to reduce the chance of detonation.
Unless you have a hole cut in your radiator shroud, none of the cool air from the air dam is going to make it to your Blackwing. The hood seal does an excellent job of keeping dirt and water off the Blackwing, but it also prevents air from entering the area occupied by the Blackwing, leaving the overly hot air from the engine compartment as your source of intake air. The solution that I made use of was to replace the fog light surrounds, which are solid, with a set from one of the vendors (can't remember exactly who right now, maybe West Coast Corvettes) that have a diamond pattern grill area to allow cold air to enter the air filter area from under the front bumper. Made a huge difference - even sitting in traffic idling, my air intake temps almost never get higher than 125 degrees, and once moving return to ambient temperature within seconds.
Some guys just take the existing fog light surrounds and drill or burn a series of holes through the plastic to create the same effect. I chose my method because I am kind of **** about appearances and the diamond grill pattern looks much better than a bunch of holes burned/drilled through the plastic. If I remember correctly, the new fog light surrounds cost me around 70 or 80 dollars.
Old Jan 11, 2007 | 11:41 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
You need a Cold Air Intake system.. With my Honker, intake temps usually run 10~15 degrees above ambient; for example, scanning this time of year reveals IAT's around 75 degrees.
Old Jan 11, 2007 | 01:52 PM
gpracer1's Avatar
gpracer1
Honk her and never look back.
Just imagine, 1% horsepower lost for every 10 degrees higher intake air. 75 degrees or 160? do the math.
To High Air Temp
