Power window noise/problem
Old Jan 11, 2007 | 07:19 PM
Mr. Jean's Avatar
Mr. Jean
Default Power window noise/problem
Hello everyone. I'm new around here, so forgive any screw ups.
I have a 2001 Coupe and only had it a week now. The drivers side window started making a grinding sound when lowered and raised. I've tried not to use it, until I get some advice. It almost sounds like a rock trying to scratch glass, for lack of a better identification. It is a grindy sound though.
Do you think it's the motor or is there something else going on? Has this been a problem in these C5's? I've never taken a door apart and would hope I didn't have too, but......
Anyone have any input about this or is there a place that covers this?
Thanks for your help. Jean
Old Jan 12, 2007 | 09:01 AM
tomas721's Avatar
tomas721
Mine was doing that and after about two weeks it stopped working altogether. I took it to the shop and they said that the window regulator was binding. It was replaced and that fixed the problem.
Old Jan 12, 2007 | 09:03 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I had the same.
Old Jan 12, 2007 | 04:02 PM
Mr. Jean's Avatar
Mr. Jean
Ouch! That's what I was afraid of. I just check and they wanted $384.00 for that puppy. Not what I wanted to hear guys. Guess I'll have to skip a mod and get this done while it snows.
Thanks for the assist.
Old Jan 12, 2007 | 09:19 PM
double-oh-coupe's Avatar
double-oh-coupe
Check the PARTS section ... sometime there are cars being parted out and you can find a used one for a little less $$$.
Old Jan 12, 2007 | 11:17 PM
tomas721's Avatar
tomas721
Also check with Gene Culley at http://www.gmpartshouse.com.
Old Jan 13, 2007 | 08:01 AM
Mr. Jean's Avatar
Mr. Jean
Thanks guys. I'll check them out.
Old Jan 13, 2007 | 09:19 PM
kevin40zx's Avatar
kevin40zx
Sounds like the same problem I had.
http://forums.corvetteforum.com/show...indow+grinding
Old Jan 20, 2007 | 07:42 PM
Mr. Jean's Avatar
Mr. Jean
Got it done. Thanks everyone.
Old Jan 20, 2007 | 07:59 PM
cruisemon's Avatar
cruisemon
Check forum vendors and others, including "that" auction. The regulator assembly is about $120 if you don't pay retail at the dealer. If you can operate a wrench and a screwdriver, you can replace the regulator. Search on this forum for regulator replace.
Charlie
To Power window noise/problem
