halltech stinger question please help
Old Jan 13, 2007 | 12:50 PM
robert123's Avatar
robert123
Default halltech stinger question please help
I just brought a halltech stinger from a member and installed it . All the fittings are on the unit except the little 1/8 tube that went into the stock bellows. what do I do with the 1/8 tube? Do I drill a hole in the halltech belllows? Please help. This is a 97 and the tube goes somewhere into the intake .
Old Jan 13, 2007 | 05:10 PM
Dave68's Avatar
Dave68
A CF member wrote this:
"It took alittle elbow grease. You will need to carefully push and pry the IAT out of the rubber grommet it is in. Push it from the inside of the airbridge and then pry it from the outside using a flat screwdriver. You have to be careful not to pull it out to fast because the sensor can break. Once the IAT was out, you can then easily remove the rubber grommet and then reinstall it on the Stinger airbridge. Then you slide the IAT into the grommet."
I believe you should be able to drill the appropriately-sized hole in the Stinger airbridge. Just to be sure, why don't you email Jim Hall? He should get back to you fairly quickly; at least he always has whenever I had a question. His website is www.corvettec5.com
