Daytime lights
Old Jan 15, 2007 | 03:03 PM
montec's Avatar
montec
Default Daytime lights
I would like for my daytime running lights to be clear vs yellow. Is it possible to change the bulb, please provide part number, or must I change the entire light assembly. Thanks
Old Jan 15, 2007 | 04:18 PM
DeeGee's Avatar
DeeGee
The DRL bulb is a dual function bulb and gives you turn signals as well as DRL. If you change out the amber DRL you'll have white T/S. That may not be legal in some States.
The normal bulb is a 4157NA (with the "A" being amber) but a 3157 will fit . You can get a white bulb (or LED) which is the equivalent to the amber.
