Where's the tach wire
Old Jan 17, 2007 | 07:52 AM
adown's Avatar
adown
Default Where's the tach wire
Hi guys, can someone tell me where a tach output wire is under the hood of a 00 C5 coupe. I need it to hook up my NOS window switch. I'm hoping its not under the dash. Thanks, adown
Old Jan 17, 2007 | 09:03 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
http://forums.corvetteforum.com/show...um_id=1&arch=1
Old Jan 17, 2007 | 11:05 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
If you don't want to go under the dash, the pcm is located behind the passenger front wheel. You'll find a plastic panel in the fenderwell. Turn the wheel and you can get to the screws. The two PCM are under there (basically under the Battery).
Pin 10, white wire.
Old Jan 17, 2007 | 02:32 PM
Z O SICK's Avatar
Z O SICK
Pin 10, white wire.
You got it That's what I used for my shift light.
Old Jan 17, 2007 | 03:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have to wire mine up soooon!!
BC
Old Jan 17, 2007 | 06:22 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Pin 10, white wire.
EXACTLY !!
To Where's the tach wire
