Injector issue
Old Jan 18, 2007 | 05:13 PM
Jamn's Avatar
Jamn
Default Injector issue
I have a 2001 C5 with about 45,000 miles on it. It has a miss while idling, and after adding a bottle of injector cleaner, the miss stops. The problem is that after adding the cleaner, it only seems to last for about 1500 miles. If it’s not throwing a code, is there any way to determine which injector is sticking?
Old Jan 18, 2007 | 06:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to isolate the miss down to a single cylinder and work from there. It easy to swap injectors around to see if that is the issue. My guess is that is not an injector but a wire or a plug. Examine your wires for damage and measure the internal resiastace of the wire. It should be 250 - 750 ohms.
Bill C
Old Jan 18, 2007 | 07:06 PM
vettenuts's Avatar
vettenuts
Couple of other suggestions. You can do a balance test on the injectors to find out if one is sticking. I bought the tool at Autozone, not sure if they rent it or even still sell/make it. Its made by Actron.
Actron Tool
Other option would be to start running FP60 in the fuel for a while. You can find this here:
FP60
Old Jan 18, 2007 | 07:11 PM
Jamn's Avatar
Jamn
I tried to get the boots off of the plugs, and they're like glued on. I'm afraid that I'll damage the wire trying to take them off. Is there a tool that can help with this?
Old Jan 18, 2007 | 10:38 PM
Alfcarguy's Avatar
Alfcarguy
Push the wire connector in and turn than pull I believe thats what they say to do in the Tech stuff. Put a scan tool on it, it should tell you what injector is missing if there is one missing, by giving you a miss fire code to one of the cylinders.
Or you can do an Ohm's test to the injector. All the injector is red and black like a battery just put the meter leads red to one and black to the other one and get a ohms reading.
The ohms are 11.0-14.0 ohms.
Hope this helps
Old Jan 18, 2007 | 10:47 PM
nitrojunky's Avatar
nitrojunky
everytime I've had a misfire like that, I replaced the plugs/wires and it magically got better... especially with 45k on the set
Old Jan 19, 2007 | 06:55 AM
see5's Avatar
see5
If you have 45k and the plug wires are "glued on " then it is time to change plugs and probably wires.
Old Jan 19, 2007 | 08:50 AM
vettenuts's Avatar
vettenuts
Injector wires or plug wires? I couldn't get my plug wires off after 5K miles so your not alone. Have bandaid's at the ready. I ended up putting on new wires.
Old Jan 19, 2007 | 09:00 AM
99 vett babycar's Avatar
99 vett babycar
Old Jan 19, 2007 | 02:59 PM
Hawkdriver's Avatar
Hawkdriver
There are some injectors on sale in the sales section. I just bought 8 new ones for $100. He still has 7 sets left!
To Injector issue
