Corvette Paint?
Old Jan 21, 2007 | 03:04 PM
Wickd1's Avatar
Wickd1
Default Corvette Paint?
I have a 2000 arctic white vette , very good shiny paint on it, i just had a spare glass top painted to match the car, i got dupont paint and clear , we just put the top on to see how it looks but its a little whiter ( bluer than my car) is it hard to get these to match perfect? he used a grey sealer and he is a pro. he just says some clears will yellow over time or maybe the factory paint isnt dupont, any thoughts on this matter?
Terry
Old Jan 21, 2007 | 04:17 PM
RJS2000VETTE's Avatar
RJS2000VETTE
I don't think your car has a clear coat. If you look at the different colors for 2000 GM only mentions clear coat on the Mel. yellow and the mag.red. I always take something off the car like the gas door lid and have it color matched at the paint supply store.
I have a 2000 silver and I am doing some repair to the bumper cover and when I sanded it the substrate (primer) was dark gray. You may want to check and see what color primer was used at the factory, it will make a difference in the color match.
Old Jan 21, 2007 | 04:32 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Your car is clear coated.
The best way I've found to match paint is to take a piece to the store and have them scan it, even a color as simple as White has many different shades.
Also, sometimes different colors use different base coats, for instance if you spray a part gray and then the top color blue you might wind up with a different shade then if your base coat were black with a blue topcoat.
Old Jan 21, 2007 | 04:50 PM
FreddyG's Avatar
FreddyG
I might be mistaken, but I think the OEM paint is PPG. Maybe someone with more knowledge will correct me if I'm wrong.
Old Jan 21, 2007 | 04:52 PM
BlackZ06's Avatar
BlackZ06
All Corvettes have a clear coat, but the MY and MR "clear" coats actually are tinted to enhance the "depth" of the paint.
Most body shops today use a computer based color matching system that scans your current vehicle's color and then mixes the paint to match. This avoids issues such as original paint vendor (DuPont, PPG, whichever) and the change to the color that inevitably happens over time.
If you had a "pro" do the paint, I'm surprised they didn't use a computerized paint matching system.
Old Jan 21, 2007 | 04:59 PM
cruisemon's Avatar
cruisemon
Originally Posted by White-C5
we just put the top on to see how it looks but its a little whiter ( bluer than my car) he used a grey sealer and he is a pro.
When you say used a grey sealer, do you mean he put a tint in the clear? If so, you answered your own question. Your clear coat shouldn't have a tint. The observation that SOME clear coats yellow over time falls into the category of the guy who goes to a doctor, raises his arm over his head and says "It hurts when I do that" to which the doctor says "Well don't do that". To the pro painter, use one of the clears that DOESN'T yellow over time and don't put a grey tint in it.
I think you need and are due a repaint.
Charlie
Old Jan 21, 2007 | 11:51 PM
mnfmkf's Avatar
mnfmkf
I think Du Pont purchased PPG.
And white may not be a clearcoated color.
Mike
Old Jan 22, 2007 | 02:19 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
They are all clear-coated, no ifs ands or buts about it.
Old Jan 22, 2007 | 03:46 AM
Blown 346's Avatar
Blown 346
This might help, It wil ltell you what the exact color is for what year Corvette you own.
http://www.corvettepaintcodes.com/
Old Jan 22, 2007 | 09:50 AM
dougbfresh's Avatar
dougbfresh
All Corvettes since 1982 use basecoat/cleatcoat paint systems. The primer/sealer color will effect how a color like white appears. The lighter the lighter the color will look.
Old Jan 23, 2007 | 06:35 AM
OzzyC4's Avatar
OzzyC4
Terry
ALL paint changes color with age. I would wager that your paint is mixed correct by code , its just that it is mixed to match the paint as originally sprayed, not after 6 years of fading.
A good panel repair painter will add a bit of toner to his paint until he gets a match with the aged color he is matching.
Painting is an art, not a science. The computer matching imho is just a ball park guess. a good eye and experiance can always beat the computer on matching color.
Old Jan 23, 2007 | 07:07 AM
y2kvette magnetic's Avatar
y2kvette magnetic
magnetic red had tinted clear coat which makes it difficult to match and each car has to be matched there isn't a standard formula
To Corvette Paint?
