Suspension - What Next?
- HOTCHKIS SWAYBARS
- BILSTEIN SPORTS SHOCKS
- TUNNEL PLATE
- DTE BRACE
- LOWERED on stock bolts (if that matters?)
I am really interested in a set of ZO6 springs, but I am interested in hearing everyone's opnion. The coil is just to much $$$ for my blood, but I like it.
Thanks in advance,
Micah
What am I looking for? Well, I want a stiffer sportscar. I like the ride now, but the ZO6 springs will give me a little bit of a lower stance and will give me the ride (both stiffness and performance) I want. I was curious what others have done.
Micah
...Hotchkis sway bars with metal adjustable end links...
...Bilstein shocks
...lowered on stock bolts...
StuzVette rides great and solid in 90 degree turns
Tunnel plate not installed...
...after riding on Hotchkis and Bilsteins...
Im done...
peace
Stu
- HOTCHKIS SWAYBARS
- TUNNEL PLATE
- DTE BRACE
Thanks in advance,
Micah
Herbie
Food for thought,
The Z06 springs only increase rates approximately 10% over base spring rates, which we found is an improvement but not enough. We found 25% or greater yield better Handling results with only minimal ride quality impact. The key for ride quality is to have the shock valving to work well with the spring. For none adjustable shocks the Bilsteins are our choice.
With the addition of Paul Lesinski to our staff, our suspension kits, have input from Dan Kellermeyer, Dan Popp and Jerry Onks and collectively, over the years, have addressed various handling issues. One common thread was the excessive nose dive under hard braking. To solve this we increased spring rates rather than increase the bump in the shocks. By reducing the nose dive under braking we did not unload the rear tires as much, which keeps the ABS activation to a minimum. We also found the increased spring rate increase cross weights in cornering, also a plus. With a dual mounted transverse leaf spring, energy is transferred side to side, which helps reduce roll similar to an anti-sway bar and reduces the need for huge bar diameters. We also found when we increased the shock stiffness in high speed valving we lost tire compliance on broken road surfaces, and by having a softer valve we maintained tire compliance and reduced harshness.
Plus surprisingly, ride quality, is firmer but not harsh. In simple terms, spring rates effect firmness and the shock valving effects harshness. The more aggressive suspension kits can feel more "European" in ride quality, not truck like...
Currently, the Hyperco and the VBP composite springs offer the rates to accomplish these goals needed in performance handling. Depending on your goal, we can custom tailor the rate to your need.
Hope this helps,
Van Steel
