centerbolt valve cover queston PLEASE HELP
Old Jan 22, 2007 | 10:22 PM
LEANDRO's Avatar
LEANDRO
Default centerbolt valve cover queston PLEASE HELP
i got a set of centerbolt valve covers from a guy from ls1 tech. when i got them i found out that i need the 90 degree fitting that goes into the drivers side valve cover grommet twords the fire wall. The fitting goes into the grommet and is used for the pcv valve lines. does anyone know if i can get these buy them selves and if so part numbers? i talked to a dealer and they said that i come with the valve covers. i can 't imagine that you can't get this part by itself. my h/c set up is almost ready to fire up so i am going crazey and am running out of extra money
Please help
Leandro
Old Jan 23, 2007 | 05:44 AM
vettenuts's Avatar
vettenuts
If you go to a plumbing store, you should be able to fit up a brass fitting with a 90 degree leg. Check this thread:
Mike Mercury Mod
