climate control irratic
Old Jan 23, 2007 | 09:27 PM
Wayne's World's Avatar
Wayne's World
Default climate control irratic
I have searched and have come up empty.
My outside air temperature probe is broken. It reads 127 f. Way off!!
I disconnected it and checked the plug for corrosion and re attached it with no change.
The Climate control on automatic blows hot at 86 degrees or above only. After a while it blows cool. Could it be because the probe is broken?
I have just bought the car and do not have a repair manual yet. Any suggestions?
Old Jan 23, 2007 | 11:46 PM
Blown 346's Avatar
Blown 346
The one reason why you get warm air instead of constant cool air incoming is the sensor inside the car.
Here is a link to help you out. http://www.digitalcorvettes.com/foru...ad.php?t=69755
Old Jan 23, 2007 | 11:54 PM
striper's Avatar
striper
The broken temp probe will definetely mess up the climate control. I know, I had one go bad on me. It is inexpensive and very easy to replace, it just plugs in.
Old Jan 24, 2007 | 08:17 AM
Wayne's World
Thanks for your input.
For about ten bucks that would be a cheap fix.
To climate control irratic
