some questions?
Old Jan 22, 2007 | 11:09 PM
TTK98's Avatar
TTK98
Originally Posted by BlackZ06
I already posted that with this DTC, the PCM may not allow the engine to start. It does this by not firing the fuel injectors and/or the coils. You either have a wiring problem (most likely) or a bad TAC. You need to look into the areas where you may have disturbed the wiring.
Check that fuse #17 in the engine fuse block is good
Check any and all connectors that you took apart. Look for bent pins, bad contacts, whatever. This problem is most likely a wiring issue .... the service manual indicates that after checking all wiring, the only possible solutions are to replace the TAC and then the PCM. Those are "expensive" solutions that you will need a dealer (or someone with a Tech2) to perform.
The battery could also be bad. Pull it out and check under it for signs of battery leakage on the wiring. At this point the Tac & Pcm are visible under the battery tray. You didnt say if codes were C or H , if they were History they may not have anything to do with it.
If the car ran prior to this perhaps you disturbed an already poor ground or connection. Another suspect area to check is the harness at the firewall driver side at valve cover.Sometimes cuts through on the angle bracket rear of fuel rail.
Could it be grease on your key pellet ?
Good luck with it.
Old Jan 22, 2007 | 11:13 PM
shihiran's Avatar
shihiran
U1064 Lose of Communications with DCM WHAT DOES THIS MEAN
Old Jan 23, 2007 | 12:09 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You PMed me and said that the car will not turn over but here you state that " it crank but it want start the engine." Well,,,
Which is it???? Makes a BIG difference in troublesooting!
PLEASE give a detailed explantation on what issues your having.
BC
Old Jan 23, 2007 | 12:23 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOSS OF COMMS means that a module is not communicating on the serial buss. If it is being shorted to ground,,,none of the other modules will respond either. The most common cause of this issue is a shorted door cable connector. Ther could be other issues that can cause a morule issue. Like a blown fuse, bad ground, etc:
Hhere is the door connector that is a known issue!!
Old Jan 24, 2007 | 11:52 PM
shihiran's Avatar
shihiran
Battery Is Now Charged New Code Come In Only One.my Car Is A 98 Automatic.what Does This New Code Mean.
P1571 Hc -asr Desired Torque
Old Jan 25, 2007 | 08:17 PM
shihiran's Avatar
shihiran
so whats does this mean?
Old Jan 25, 2007 | 10:28 PM
shihiran's Avatar
shihiran
Default some questions?
does anyone know whats this code mean for a 98 automatic
"P1571 HC ASR Desired Torque"? and if your MAP sensor is bad will your car start.
Old Jan 26, 2007 | 12:36 AM
shihiran's Avatar
shihiran
and code P0108 c what does that mean?
Old Jan 26, 2007 | 01:19 AM
FRCTony's Avatar
FRCTony
Manifold Pressure (MAP) Sensor Circuit High Voltage
I'd worry about this first, then see what happens.
Have you done any work to the car recently?
Old Jan 26, 2007 | 01:20 AM
BlackZ06's Avatar
BlackZ06
You have another wiring problem .... the PCM and EBCM are not communicating properly. The PCM set this code because it is not receiving the "requested torque" message from the Traction Control function of the EBCM.
