Wiper arm removal
Old Jan 28, 2007 | 11:48 AM
UmCanesZ06's Avatar
UmCanesZ06
Default Wiper arm removal
I am trying to get the wiper arms off of a 03 Z06. I already took the nut off, but the wiper arm does not come off very easily. Is there a special tool required, or can I use a screwdriver? Thanks
Old Jan 28, 2007 | 11:56 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
There is a special puller made for this...but you can usually get the arms off with enough wiggling.
The splined shaft the arms attach to has a slight taper, so it can make removal tough. Just try to rock the base of the arm back and forth while pulling upwards. Once you break the "seal" of the tapered fit, they will literally jump right off.
I've had mine off 3-4 times and never needed a puller.
Old Jan 28, 2007 | 12:20 PM
UmCanesZ06's Avatar
UmCanesZ06
Thanks for the info.
Old Jan 28, 2007 | 12:53 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
A battery terminal puller works great.
Old Jan 28, 2007 | 09:03 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Make sure to lift wiper off of winshield first and lock open.
Old Jan 29, 2007 | 02:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have screwed the nut down flush with the top of the shaft, lift the arm up off the window, lift up on the base of the arm and tap the nut lightly with a hammer. It popped right off.
BC
Old Jan 29, 2007 | 11:45 AM
TEXHAWK0's Avatar
TEXHAWK0
I have a small puller made for the job. I like it because I don't have to beat or pull on the wiper shaft and risk damaging the shaft or linkage.
Old Jan 29, 2007 | 03:21 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
This is what I use....................
http://www.kd-tools.com/2039.htm
To Wiper arm removal
