Output Shafts
Old Jan 28, 2007 | 12:09 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Default Output Shafts
What all is involved with the installation of the output shafts?
Can it be done by a DIY'er?
What is the best brand to go with.
Old Jan 28, 2007 | 01:39 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Also should I go with just the long shaft or replace them both?
Old Jan 28, 2007 | 02:34 PM
Dave00C5's Avatar
Dave00C5
You can install them yourselve if the diff is out. The longer shaft is more prone to breakage but i'm running both as a safety measure. I strip run the car so breakage is a cionstant concern. Hope this helps in your decision.
Old Jan 28, 2007 | 03:38 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Did you do the swap your self?
Also, what all tools are required to change the short shaft?
Old Jan 28, 2007 | 11:50 PM
4DRUSH's Avatar
4DRUSH
You would be better off to ship the rear to RPM and have them do it.
Old Jan 28, 2007 | 11:56 PM
chriswtx's Avatar
chriswtx
I did it myself. Its not that hard. Here is a write up on it...
http://www.c5frc.com/DIY/Hardened_Ou...haft/index.htm
Old Jan 29, 2007 | 04:48 AM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Thnaks for the link. That is what I was wanting to see.
Old Feb 15, 2007 | 04:10 PM
berryj's Avatar
berryj
Hey Bobby, looks like I'll be getting my output shafts done as well. I'm planning on getting both sides done as it I'm upgrading to a Level 4 RPM tranny plus a Vig 2800 converter. I'll be driving to Indianapolis to Rodney's shop to git R dun as they say around here!
Did u do yours already, and if so, both sides?
BTW, Bristol street fights begin 3/3, but I can't make that one anyway.
Hopefully I'll be at the April one.
Old Feb 15, 2007 | 04:44 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
No I haven't getten mine done yet. I will soon though.
Still have to finish up the engine work first, changed cam, swapping pulley and using restrictor plate and puttin in 60# injectors and a BAP.
Then I am going to get the output shafts, differential strut and some ET Streets.
Old Feb 15, 2007 | 09:30 PM
berryj's Avatar
berryj
Sounds like a serious power increase is about to occur! Let me know how it goes and have fun! I have the MSD BAP which has worked well for me.
Old Feb 15, 2007 | 09:59 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
It should pick up a little power, nothing crazy as I will be keeping the boost around 9psi, but will come in a little quicker.
The MSD is the one I picked up too.
Old Feb 15, 2007 | 10:00 PM
Irish Whiskey's Avatar
Irish Whiskey
have hardened output shaft, but alas, at age 62 it is the one in my 2000 vette
Old Feb 18, 2007 | 02:23 PM
berryj's Avatar
berryj
Just for my own knowledge, what will swapping the pulley do if it doesn't increase the boost? Mine is a 4.10 pulley and I thought if one goes to a smaller pulley, you will thus turn the blower impeller more times per rotation of the belt and therefore create more boost.
Old Feb 18, 2007 | 02:54 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
It will create more boost. I am pulleying down and using a restrictor plate to keep it around the boost level that I was running with the 4.1 pulley.
Old Feb 18, 2007 | 07:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OUTSTANDING write up on the long shaft! How hard is it to replace the SHORT shaft?
BC
Old Feb 18, 2007 | 07:38 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
BC
I would like to know myself..............Paul
Old Feb 19, 2007 | 12:28 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Good one.....
Clayton from Las Vegas
Old Mar 18, 2007 | 11:05 PM
NigelTufnel's Avatar
NigelTufnel
BC
I just installed both shafts in about 2 hours (diff was already out of the car). Not very hard, in my opinion. In addition to the tools listed in the long shaft write up, you will need a press and a pickle fork (tie rod splitter or equivalent).
Follow the write up for the long shaft. Once you have the case split, take the portion with the short shaft and set it in the press. Place the pickle fork around the cross pin so it straddles the pin, and then use the press to compress the bellville washer and clutch pack.
Don't over do it on the pressure. You need just enough to slide the cross pin out. Once the pin is out, remove the two side gears and washers, and release the pressure. You now can remove the short shaft. If you remove the clutch packs, make sure you keep them in the same order.
Reverse the above to reinstall. During the reinstall, make sure the holes in the cross pin align with the holes in the case (use the case bolts to align the two as shown in the picture). Once aligned, release the pressure and reassemble the case.
Also, when torquing the case bolts, I set the case in the press and applied light pressure so as to keep the case from rotating while torquing the bolts.
To Output Shafts
