Car is hard to control
Old Jan 28, 2007 | 01:27 PM
Secret237's Avatar
Secret237
Default Car is hard to control
OK, here’s the deal, my C5 is hard to control at times. It’s not like I’m going to wreck or anything, it just goes off and I have to correct for it, one way then the other, kinda fast, but not like a vibration.
It jumps to the right or left under the following conditions:
Ruts on freeways
Under hard acceleration
Under hard braking
It’s like it “darty” so I adjusted the front Toe-in a bit (1/4 turn each side) and that helped, but it still jumps around a little.
I think it just needs an alignment but I don’t know where to take it here in the Portland, OR area (Beaverton).
All stock, with factory run-flats.
Any ideas ?? This isn't normal is it ??
Old Jan 28, 2007 | 04:12 PM
BUSMAN C6's Avatar
BUSMAN C6
From my short time here sounds like you have tire hop from older G Y runflats. i went to MICHELIN ZPs and lost the tire hop
G L
Old Jan 28, 2007 | 04:16 PM
rgtkst's Avatar
rgtkst
run flats will amplify this condition. a switch to good set of non runflats changed this dramaticly on mine. and the ride is much better. and they cost less. and much quieter. i had to tweak my alignment a bunch to keep it from wondering to the left with the runflats. put on the non runcraps and it went to the right instead. sooo.... had to align again and all good now. i lost a bunch of the "bump steer" also
Old Jan 29, 2007 | 12:17 AM
4DRUSH's Avatar
4DRUSH
Lose the run flats and get new shocks.
Old Jan 29, 2007 | 12:24 AM
vettencle's Avatar
vettencle
Get rid of the run flats!! Not worth the $$ or the crapy ride they give!!
Old Jan 29, 2007 | 10:09 AM
Billdog350's Avatar
Billdog350
I had this problem when my car steering sensor was throwing codes. Looking on the website here and the GM manual led me to believe that the magnasteer will go to full boost (no magnetic dampening) when the codes are thrown...therefore giving you full power steering on the highway rather than minimal boost. I can verify that my steering was VERY sensitive with the C1281 code being thrown. Once I solved that problem (clean the contacts, as seen in the sticky by Bill Curlee) the steering was MUCH better and felt much safer and less jumpy. I don't know if this applies to you but I figured I'd throw it in there.
Old Jan 29, 2007 | 10:15 AM
EHS's Avatar
EHS
Here an answer from an old timer:
1. Some of it could be normal, depending on what you were driving before the C5. Tram-lining is normal for this car, depending on how deep the ruts are.
2. Have an alignment done (what is the wear pattern on the tires). It sounds like you have been doing the adjustments yourself -- go to any decent alignment shop, and for now, just go back to factory stock.
3. How many miles? Do you have the F45? You may need new shocks, especially the rears.
4. Check (or have smeone check), the suspension connections, especially the sway-bars -- are the endlinks OK?
Etc., etc. -- don't worry so much about steering sensors and tire brands -- go check the basics first, which in your case, sounds like a proper alignment.
Old Jan 29, 2007 | 11:09 AM
KidCid's Avatar
KidCid
CI 7-8 Veteran
As it was once explained to me, bump induced side step is directly related to the very stiff sidewall of the runflats. New tires should fix that problem.
Old Jan 29, 2007 | 04:50 PM
vettenuts's Avatar
vettenuts
I dumped the run flats and went with Goodyear GS-D3's, all the problems you describe are now gone
Old Jan 29, 2007 | 07:56 PM
Secret237's Avatar
Secret237
I have been doing the adjustments myself, just a quarter turn per side to Toe it in a little more, helped.
My car has 40,000 miles on it now , FE1 Base Suspension and F45 Selective Real Time Damping, sway bar and end links looks good, plastic end links, but still ok.
When I did my adjustments, I could tell that someone else had been there making their own adjustments.
I tend to think you are right, I need to have it aligned, I also tend to think it's more than just the tires.
No codes.
I haven't really checked anything in the rear, I guess I should do that.
Thank you all so much for helping, I actually didn't enjoy driving my car last weekend ... gotta get this thing fixed !!
Old Jan 29, 2007 | 09:33 PM
superjet701k's Avatar
superjet701k
im new to this forum so i hope im doing this right ,flame suit on, i just bought my 01 vette last week and it has f-45 susp. now it definalty climbs allover New England rutty roads but is smoothe on a good highway. how long are the f-45 shocks good for and are they worth replacing with oem.
Old Jan 30, 2007 | 12:49 AM
EHS's Avatar
EHS
The F45, eh?
That's why I mentioned it in my #3 above -- I had the front shocks replaced under warranty with only 33,000 miles, because the car was really squirrelly under hard acceleration, especially in turns.
I think you may have a combination of problems -- alignment, and definitely check the shocks as well.
The suspension was designed for the run flats -- don;t worry about the tires -- I use F1s in the summer on Z06 wheels, switch back to runflats in the winter -- the tires aren't the issue, unless they have irregular wear.
Old Jan 30, 2007 | 12:52 AM
EHS's Avatar
EHS
I had two replaced under warranty at 33k, now have almost 80k on the car. They seem OK for now, but on my list of things to do.
$1,800 for the OEM, $2,200 for the F55 upgrade.
Old Jan 30, 2007 | 09:08 PM
ddudas's Avatar
ddudas
1st Gear
I have a 2001 vert with the F-45, rear shock adjuster manfunctioned @ about 28k. This causes a inbalance in the shock rates which provide some strange handling issues. Highway groves made the car seem “darty”, and bump induced side step increased on broken side. Mine were replaced under warrenty, problem fixed.
Old Jan 30, 2007 | 09:22 PM
EHS's Avatar
EHS
Exactly...
Old Jan 31, 2007 | 09:15 AM
Secret237's Avatar
Secret237
I don't like all this talk of $1800 shocks .... I think I can get them for $1600, What a deal !!!
No
I am going to try an alignment first, cheaper and it's the thing to do because my Toe-in adjustment did seem to help.
I was under there yesterday and I noticed the rear sway bar did have some give to it, with me moving it by hand, mostly around the plastic sway bar links.
Can anyone give me some part numbers of the metal sway bar links ??
Stock sway bars.
What is a shock adjuster ??
I really need a service manual !!
Old Jan 31, 2007 | 11:33 AM
EHS's Avatar
EHS
Call Bob Wendorff at Fichtner Chevrolet -- he will be cheaper than the local guys, and he has been through this a thousand times.
He has all the parts numbers in his head as well.
To Car is hard to control
Old Jan 31, 2007 | 11:44 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
its all about allignment (possible broken suspension parts) and a fresh set of good non run flat tires is what you need.
FWIW, I drove down the freeway with my road racing slicks on the car. Perfect allignment and all.. the car swerved like crazy on all the expansion joints and grooves on the highway. Too much traction = damn near wrecking the car!!
VR
Old Jan 31, 2007 | 08:17 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
I will have some answers for you by tomorrow. I plan to get an alignment first, then I will be getting some nonruncraps, so I will see the difference after alignment and then after new tires. More to follow.
Old Jan 31, 2007 | 08:34 PM
robertp's Avatar
robertp
I had the same problem when I first got my '99. The run flats on the front were pretty worn so I replaced them with non run flats. Problem was gone after that.
