Z06 Heads?
Old Jan 29, 2007 | 06:10 PM
DBLX's Avatar
DBLX
Default Z06 Heads?
Ok guys, are the Z06 heads significantly better than the stock C5 heads? Would this be a worthwhile upgrade?
TiA,
MJ
Old Jan 29, 2007 | 06:42 PM
AU N EGL's Avatar
AU N EGL
YES. You can get some ported and polished LS6 heads. Much better air flow. Combine with a good cam and let the begin.
Old Jan 29, 2007 | 06:45 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Add a cam at the same time!
I added a MTI R1 cam to a set of mildly cleaned up 243 heads (& LT's) and pulled 420 RWHP.
The heads are an improvement over the 241/853 heads. Since you already have the topend off, pull the steering rack and do the cam.
It will make you smile!!!
Bob K.
Old Jan 29, 2007 | 07:12 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I wouldn't bother unless you are going to port them and throw a cam in.
Old Jan 30, 2007 | 08:18 PM
vettesrnice's Avatar
vettesrnice
Heads with no cam are not worth the cost. motor is like a air pump a big restriction is the cam. (this would be first thing I would fix most HP bang for the buck), then heads, then air intake then exaust in this order. cam lets in air longer and opens valves higer.
Old Jan 30, 2007 | 08:47 PM
SLPRC5's Avatar
SLPRC5
TiA,
MJ
I now have the 2002 LS6, ZO6 cam,LS6 intake and shortie headers it is a great improvement over the LS1 heads, cam and intake. I dynoed 349 RTWHP and 351 RWTQ with this setup. But as the mod bug has bit again, I'm removing the heads and cam to go with a larger cam and Patriot heads in a few weeks.
SLPRC5
To Z06 Heads?
