Royal purple???
Old Jan 29, 2007 | 11:21 PM
biglu187's Avatar
biglu187
Default Royal purple???
What do you guys think of Royal Purple? I used it in my import tuner days(last month ) and really liked it. Anyone using it in their vette?
Old Jan 29, 2007 | 11:30 PM
uncle52's Avatar
uncle52
St. Jude Donor '06-'07
Default rp
all you have to do is look on the search to see that RP, Amsoil, and Mobil 1 are top rated. are you looking to RP your engine or your tranny? I use Mobil 1 on engine, RP soon in my six speed. Should do real fine.
Old Jan 30, 2007 | 06:18 AM
vettenuts's Avatar
vettenuts
I have done a lot of reading over on bobistheoilguy.com and RP really hasn't shown very good results. The German Castrol has actually shown the best wear numbers and its available at Autozone for the same price as other synthetics. I now run this in all my cars.
Old Jan 30, 2007 | 07:57 PM
DADEO1's Avatar
DADEO1
Default Royal Purple
I am running it in my 99.
Oil and rear end so far.
Will be doing the transmission in the spring.
The car seems to run strong with it and has elimated some nosie
I was getting from the rear end.
Sold me.
And it has been proven by dyno test you gain 9 to 10 hp from doing the motor, trans and rear end.
Old Jan 30, 2007 | 08:17 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
All my fluids are Royal Purple. Works well for me, no problems.
Bob
Old Jan 30, 2007 | 08:50 PM
SLPRC5's Avatar
SLPRC5
Bob
same here
Old Jan 31, 2007 | 11:57 AM
FKING1's Avatar
FKING1
Originally Posted by SleeperC5
same here
Same here
Old Jan 31, 2007 | 12:15 PM
LRD VDR's Avatar
LRD VDR
same here
Shahram
Old Jan 31, 2007 | 01:41 PM
Corvette Don's Avatar
Corvette Don
I use it in oil, tranny and rear in my vette, I have been using this in all the cars ive had for more than 3 yrs now, ill never use anything else. Oh and I still change it every 3k even though they say its good up to 10-12k miles
Old Jan 31, 2007 | 03:41 PM
Mach2's Avatar
Mach2
Just got a 98 C5 6 speed with 44k miles. 90% oil life left but I want to change the oil and filter to get it on my schedule soon. Spec rqmts. are 5w-30 Mobil 1 so I'd use the same weight Royal Purple engine oil, but what about the 6 speed and rear end? What weight RP would they use? Oh, and what oil filter do you guys use with RP? This will be my first venture into synthetic oils.
Thanks for helping a C5 newbie, a very happy one too.
Mick
Old Jan 31, 2007 | 04:32 PM
rws.1's Avatar
rws.1
The 6 speed manual tranny uses Dexron III ATF... tha tis not a mistake, that is the spec.
The rear diff uses 75W90 synthetic gear oil + 4 oz of GM limited slip additive ( or aftermarket equiv.)
any good quality engine oil filter is fine
AC/Delco
Mobil 1
Napa Gold
Wix
K&N
FKING1's Avatar
FKING1
Mick
5W30 engine
Synchromax-Tranny
Max-Gear 75W90 differential (has additive included)
Old Jan 31, 2007 | 05:18 PM
gringram's Avatar
gringram
CF Member
what he said
Old Jan 31, 2007 | 05:43 PM
99 vett babycar's Avatar
99 vett babycar
use it in trani rear end and oil - good stuff
Old Jan 31, 2007 | 05:46 PM
David426's Avatar
David426
Rp wore my rings out after 20000 miles
Old Jan 31, 2007 | 09:25 PM
Bob's 01slpss's Avatar
Bob's 01slpss
been running royal purple in all performance cars since 2002 and no problems, love it!!!
Old Jan 31, 2007 | 09:31 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
David, please give us a little more info here! Did GM do the work under warranty? RP meets any GM spec for the engine oil....
To Royal purple???
Old Feb 1, 2007 | 09:47 AM
Judas Priest Fan's Avatar
Judas Priest Fan
We use Royal Purple in everything. It is a very good oil.
Old Feb 1, 2007 | 09:57 AM
Judas Priest Fan
I doubt it was the oil. I would dig a little deeper on that one.
Old Feb 1, 2007 | 10:26 AM
Mach2's Avatar
Mach2
How many miles do you go before an oil change using Royal Purple, same as the spec for Mobil 1, 7000?
Mick
