Help - DIC Message This Morning
Here's a link.
http://www.stengel.net/diccodes.htm
One thing i can tell you, it doesnt like dyno's. when i dyno'd the car, it was flashing all kinds of lights at me becasue the rears were moving and the fronts werent.
The 1214 DTC indicates that the internal relay inside the EBTCM isn't functioning properly and you need a new EBTCM!
Hopefully you are still under some kind of warranty. If not, some people (like me) have called GM customer assistance and pleaded for help and coverage. Depending on how many miles are on the car, how long you warranty has been expired bla bla bla, some times they will help you.
IF they don't,,,there is a company on E Bay that rebuilds them for about $350 and that comes with a life time warranty. Were all gong to see this one day in our future! trust me on this one!
If you get the dealer to fix this,,,,,your not going to be cash happy!
Luckily for me, I bitched enough and screamed enough
that they helped me out.Bill
Here is a link to that Company ATE.
http://www.autoecu.com/
Original cause of problem was due to changing brake pads and getting some of the dirty brake fluid in the system. I think the was the unusual case and not typical, as I have not heard of any other cases.
The relays are in the lower section of the module surrounded by RTV
BC
Bill
BC
Bill,
Those relays don’t look as though they would be too hard to change.
Is there something special about them?
Unless your seeing a failure or malfunction and they can DUPLICATE the problem while the car is there, you are wasting your time.
cliff_ford
The module is siliconed inside the housing. I had a hell of a time getting it out. Yea, if you could figure out which one is the correct relay, it wouldnt be all that difficult. There is a surface mounted micro computer under that board covered in that STICKEY NASTY goop!!! Your NOT going to be able to fix that one if theres sonething wrong there. Break her down and give it hell!!
BC
