z06 sway bars
Old Feb 2, 2007 | 09:48 AM
firstvette99's Avatar
firstvette99
Default z06 sway bars
are stock z06 sway bars a worthwhile upgrade for a stock 99 coupe no a/h.or should i go aftermarket.
thanks
scott s.
Old Feb 2, 2007 | 10:27 AM
02gt350's Avatar
02gt350
I just did this upgrade over X-mas. I coudl tell a major difference. That faster you are going the tighter the response. Very good mod for 220 bucks
Old Feb 2, 2007 | 10:33 AM
FRCTony's Avatar
FRCTony
Best bang for your buck. Make sure you have the metal enlinks.
Old Feb 2, 2007 | 10:36 AM
Chuck01's Avatar
Chuck01
BEST MOD for price period. You will notice a difference right away
Old Feb 2, 2007 | 10:48 AM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
WHERE'D YOU BUY? DID YOU DO SHOCKS TOO? HOW WAS THE RIDE, ANY STIFFER?
Old Feb 2, 2007 | 01:31 PM
01vetter's Avatar
01vetter
Try GM Parts Direct. Very good price.
craig04c5's Avatar
craig04c5
Fitchner's or Fred Beans both forum sponsers. I did not notice any stiffer ride from the Z06 sway bars over the stock suspension.
Old Feb 2, 2007 | 02:29 PM
Sully1882's Avatar
Sully1882
Default I am waiting to see
read and heard alot of this and waitinng on my order to come in. GMPartsdirect had the best prices but send it some other method than Fedex.... they have lost my sway bars... i got the bushings and endlinks but FedEx doesn't know where the sway bars are!
Sully
Old Feb 2, 2007 | 02:36 PM
02gt350's Avatar
02gt350
i got my kit from gmpartsdirect.com they were 220 bucks plus shipping. Came with metal end links and new bushings.
Straight ride wasnt any different really, but when you turned was a great improvement. body roll was decreased by 80% i bet
Old Feb 2, 2007 | 02:37 PM
02gt350's Avatar
02gt350
Sully
thats odd. mine came all as one big package
Old Feb 2, 2007 | 02:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Also up-grade to 07/ZO6 shocks (yep,,,they fit like a glove!! ) and you will really see a difference in cornering and wheel control over wash board roads!!!
With the shocks, sways and if you add the aftermarket tunnel plate, you will think you have a new car!!
BC
Old Feb 2, 2007 | 03:30 PM
craig04c5's Avatar
craig04c5
Bill I see you have the Z51 suspension while I have the base suspension. I am guessing they did not stiffen the ride on the Z51 but was wondering if you think it would stiffen my base suspension. I already have the Z06 sways.
Old Feb 2, 2007 | 05:02 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The 07 shock dampening is not that much different than the Z51/ZO6 shocks. Yes, there a little firmer but the valving does a LOT better job at controling wheel boundce and thats what I was seeing.
My OEM shocks were fine but they have a tendancy to allow the wheels to loose contact with the road on very rough pavement.
To answer your question,,,YES,,,it will firm up your ride and provide you better wheel control. The ride shouldnt be rough, just firmer. Higher rate Springs would make a rough ride!
Throwing the car into a nice sweeping turn now feels a lot more confident and if the road is rough, she doesnt walk out as bad.
BC
Old Feb 2, 2007 | 05:17 PM
craig04c5's Avatar
craig04c5
Good info Bill, thanks. BTW I found that replacing the runflats with the GS D3's seems to help reduce wheel hop on rough roads but I've only had them for a hundred miles so it's a little early to tell.
Craig
Old Feb 2, 2007 | 06:18 PM
jim2527's Avatar
jim2527
I upgrade my stock suspension '03 to the '04 Z06 spec shocks and swaybars. HUGE difference. I notice the most improvement with the shocks.
Well worth the $.
Old Feb 2, 2007 | 06:23 PM
Specter's Avatar
Specter
How much for an install, time wise for a deecent shop? How much are the shocks and both bars and endlinks alltogeather?
Old Feb 2, 2007 | 08:17 PM
LoneStarFRC's Avatar
LoneStarFRC
Same here. BTW, anti-roll bars don't "stiffen" the ride during normal straight line driving. Shocks/springs/tires will however.
BTW, GMpartsdirect's good price is more than off set by their high shipping costs.
Robert
To z06 sway bars
Old Feb 2, 2007 | 08:27 PM
LoneStarFRC
BC
Bill, do you have the specs (size) on the Z07 bars compared to the C5 Z06 bars?
Old Feb 2, 2007 | 08:33 PM
DBLX's Avatar
DBLX
Default Suspension choices
I have the Z06 sway bars, and the metal end links. Should My next mod be Bilstein sport shocks or Z06 springs, or both?
Old Feb 2, 2007 | 08:42 PM
LoneStarFRC
If you really want "slot car" handling, do both.
