Porting Fast Intake
Old Feb 2, 2007 | 04:28 PM
gorillavet's Avatar
gorillavet
Default Porting Fast Intake
My 427 has a 90mm ported throttle body but the lsx fast intake is not ported. I have read a little about Tony Mamo's fantastic porting jobs of the tb and lsx intake. Just wondering if it would be worth the trouble and expense to persue a porting job on my fast intake. Any superduper experts out there have thoughts?
Old Feb 2, 2007 | 05:09 PM
gorillavet's Avatar
gorillavet
anybody
Old Feb 2, 2007 | 05:32 PM
thehammer69's Avatar
thehammer69
Yes
Old Feb 2, 2007 | 05:34 PM
gorillavet's Avatar
gorillavet
Originally Posted by thehammer69
Yes
Don't be so shy...elaborate!
Old Feb 2, 2007 | 05:40 PM
thehammer69
Ok...the Tony Mamo and Vengeance racing ported FAST 90/90 have shown to produce some significant gains. The unported Fast 90/90 by itself doesn't really seem to gain much until it is ported CORRECTLY.
Hammer
Old Feb 2, 2007 | 05:59 PM
gorillavet's Avatar
gorillavet
Hammer
I have a correctly ported throttle body, so that is no problem.
I have heard great things about the Tony Mamo work. Will look into that as I feel his heads as some of the best in the industry.
Old Feb 2, 2007 | 06:07 PM
vettenuts's Avatar
vettenuts
You will see gains in the lower RPMs with the ported unit, whereas the unported unit from what I have seen struggles to maintain the power that the LS6 intake and ported TB make.
Old Feb 2, 2007 | 06:10 PM
zeevette's Avatar
zeevette
I'm far from an expert, but I'm due to receive my LS2 TB back from Tony Mamo in the next couple of days. I installed my H/C, and then added the FAST/LS2 90, and had some pretty annoying drivability problems. I didn't trust myself to accurately port this TB, and have ample anecdotal testimony of Mr. Mamo's expertise, and great results. My FAST was purchased used, and was already ported, and when I first installed it, (with no instructions,DOH!) I popped a bunch of holes through the base plate. When I got the replacement piece, I had to tear apart the manifold (it's 3 pieces) and got a good look at the areas that will benefit from porting work. To my untrained eyes, it would appear the center section requires the bulk of work needed, about 95%, I'd say. I found pictures of this manifold unported over at LS1tech, and the bulk of material you need to remove is pretty obvious. I would say it's fairly simple to get at least 75% of the benefits of porting, by doing it yourself. There's a ridge on the ports where they go into the heads that's just begging to be removed and smoothed. I hear lots of talk about "port matching" the manifold's outlets, to the heads intake ports, and I call that pretty much . There's not much material on the manifolds to work with, as the gaskets that surround the ports are very close. A strong caution is warranted in this area, IMHO.
Old Feb 2, 2007 | 07:12 PM
jtkeller's Avatar
jtkeller
St. Jude Donor '07
there's a post from vengeance racing on ls1tech showing a 16hp gain by simply porting the fast intake that was on the car.
Old Feb 2, 2007 | 07:40 PM
chriswtx's Avatar
chriswtx
Good read here. Links to pics on page 2...
http://www.ls1tech.com/forums/showthread.php?t=581507
Old Feb 2, 2007 | 07:48 PM
Jeffs FRC's Avatar
Jeffs FRC
I made a post about what I did to my FAST with pics.
http://forums.corvetteforum.com/show....php?t=1609199
To Porting Fast Intake
