Need Help with resetting milage....
Feb 3, 2007 | 08:43 AM
Hi thinking of doing the HUD install in my 98 coupe, so I need a HUD acceptable cluster, with that my milage will be lost, how/who can program my correct milage into the new cluster???
Any info appreciated.
Thanks!
Feb 3, 2007 | 09:05 AM
St. Jude Donor '06-'07
I had a local Speedometer shop reprogram my new cluster when I added a HUD a few years ago. Cost me about $80. Good luck w/ your project---it's well worth the effort and cost...
Feb 4, 2007 | 08:13 AM
Thanks....
BiggieBoy for the info I will check in to that and see what I have in my area, at least I have a starting point now!
Feb 4, 2007 | 08:18 AM
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Anyone with a Tech II can change also, if I remember correctly
Feb 4, 2007 | 12:18 PM
Quote:
Originally Posted by
screw991le
Actually setting the odometer is one of the few things a Tech2 CANNOT do.
Feb 8, 2007 | 12:25 AM
Find an ACDelco Repair shop. I found one in Tampa, FL and it was under $50 IIRC
Feb 8, 2007 | 10:17 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Good for my info too as I will do a HUD in my '98 as well!
Thanks,matt
Feb 8, 2007 | 11:08 AM
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
BlackZ06
We have to send clusters out all the time to be reprogrammed.
