roller cam???
Old Feb 6, 2007 | 10:27 AM
zo6chik's Avatar
zo6chik
Default roller cam???
should i go with a roller cam?? any down falls of going this route?? help guys.
Old Feb 6, 2007 | 12:07 PM
vettenuts's Avatar
vettenuts
The standard LS1 cam is a roller cam.
Old Feb 6, 2007 | 12:25 PM
Z28TOZO6's Avatar
Z28TOZO6
The Ls6 is a roller cam also.
Old Feb 6, 2007 | 12:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The only roller up-grade that you can really up-grade to that isnt already a roller is "roller tip rockers".
You alredy have roller lifters and needle bearing "roller" fulcrum rockers.
BC
Old Feb 6, 2007 | 02:33 PM
zeevette's Avatar
zeevette
YOu also could be thinking of a "solid" roller cam. This is the modern version of solid lifters.
Old Nov 26, 2020 | 10:39 AM
calibrator's Avatar
calibrator
Have seen the roller bearings fail in BBC Super Modified class engines while working at a shop back in the '80s. Even saw one that had a needle punched into the block by the cam lobe.
Old Nov 26, 2020 | 12:58 PM
oharal's Avatar
oharal
Nothing like bumping a 13 year old thread to talk about an engine that wouldnt even fit in a C5...
Old Nov 26, 2020 | 01:50 PM
calibrator's Avatar
calibrator
Well, ... you can blame it on this F'd up site format that tailgates a "Related Thread" to the one originally clicked on. Thanks for protecting the community from Loose Cannons like Me !
Old Nov 26, 2020 | 02:16 PM
grinder11's Avatar
grinder11
To roller cam???
