DIC code
Old Feb 6, 2007 | 03:32 PM
bassspring's Avatar
bassspring
Default DIC code
Need help DIC code 10 PCM PO410 (air system-B) what part do I need and why. GMAN
Old Feb 6, 2007 | 03:41 PM
C5FORFUN2's Avatar
C5FORFUN2
I believe it is the AIR check valve for the passenger side. It is mounted behind the intake manifold and is a pain to get to. The drivers side valve is easy, the way it should be. I found a thread where you remove the hose from the drivers side that runs back to the passenger side valve and spray a bunch of WD40 in it. Then blow it on through with compressed air to free up the valve. It worked for me.
Old Feb 6, 2007 | 06:28 PM
bassspring's Avatar
bassspring
Thanx for the help, is this part called the exhaust air check valve. GMAN
Old Feb 6, 2007 | 07:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep!! Try the cleaning first. It works most of the time!
Here is a pic of the intake removed. You can see the valve on the back of the drivers head:
Here is a picture of it on a mock up C5 chassis:
Old Feb 6, 2007 | 07:51 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
LOOK HERE http://www.stengel.net/diccodes.htm
Old Feb 6, 2007 | 09:09 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
X
X
X
Hey Bill, is there anything you don't have a picture of?
Old Feb 6, 2007 | 09:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just a few things but,,,,Im working on them!!
BC
Old Feb 8, 2007 | 01:09 PM
bassspring's Avatar
bassspring
Thanx alot cleaned the valve and no more codes, so easy a caveman can do it. bassspring
To DIC code
