Question for those w/ 19 inch wheels?
Didn't like the (very limited) tire choices in the 305/30/19 size, nor do I want to give up sidewall compliancy..
I finally settled on a 285/35/19 (10.5" wheel). The footprint will be identical to the current 295/35/18, I'll have a decent sidewall, only negative is it puts my rolling diameter back to the stock C5 size, which means I'm giving up 2.8% in gear reduction.
I'll run a 265/35/18 front, a nice footprint improvement over my current 255/40/17.
With the wheels I found (SSR's at the Tire Rack, wow, what a bargin!) and the shorter sidewalls, these wheels and tires are on par weight-wise with the current Z06 sizes. Yes, I do realize I'm going backwards slightly with the rotating weight a bit further out (on the rear wheel anyway, the front is a wash).
All in all I hope the sidewalls will balance the overall look front to rear, similar to the stock Z06 setup (I've never liked 18's on both ends, makes the front wheel look much larger than the rear, where as the 17 - 18 combo looks "balanced", if that makes sense).
